Turboed 2007 2.2 Cobalts ONLY
#51
Try 325 gearbox TQ, it's an auto 4T45. If I have to worry about the tranny, then someone needs to stop me.
Remember, this is the same tranny that is put into larger V6 platforms such as the malibu.
Hey, this is cool. Apparently the new HHR SS comes in a auto 4T45 form as well. That's a whopping 260 HP/TQ in stock form!
If they can handle 260 HP/TQ reliably, then there's no question that they can hold 300+. And with a ~$500 rebuild kit, you're looking at a tranny capable of 400+. For now though, just a tune and a tranny cooler to make it giggle.
I bet you will make somewhere in the 220-230 range on 7psi. delta2.2 makes about 212whp on 5psi in his set up. but PSI is really not what everyone makes it out to be. the key is how much CFMs your turbo moves. find out that rating. mine moved 786 CFMs
#52
i have the same trany. check my video out and see what a turbo, a tune, and B&M shiftplus does to the car. http://videos.streetfire.net/video/s...-22_201264.htm
678 cfm. What's the specs on your turbo?
Btw, is that my imagination or did I hear turbo flutter?
#54
im thinking about upgrading to a 5 stage wheel once my new engine is finished being forged.
#55
so far i hear everyone likes there turbo'd 2.2
i'm hopefully gonna start my turbo build after x-mas...
GT2860RS Kit
Pistons/Rods/Balance Shafts
Custom Tune at 12 PSI
Clutch/Flywheel
Stage 2 Axles
75 Shot Nitrous
What tuning is everyone using?
i want to use LS2 Edit but i cant find a dealer out here in cali.. and supposably LS2 Edit is the best one out for the 2.2's (07+)
GT2860RS Kit
Clutch/Flywheel
Stage 2 Axles
75 Shot Nitrous
#56
well looks like your heading in a good direction....good luck in reaching your goal...im not an 07 but an 05 with parts from all the years and models...not to mention i have some ion **** on my car....you can call my car a frankenstein.
#57
u should paint ur car like a dark green jade color and get some sweet decals with frankenstein on there!
#58
GT2860RS Kit
Clutch/Flywheel
Stage 2 Axles
75 Shot Nitrous
GT2860RS Kit
Clutch/Flywheel
Stage 2 Axles
75 Shot Nitrous
#60
oh btw i still have these stage 2 cams for the 07 head for sale...i no longer require a trade...im just selling them straight up for 315....click on link on my sig if anyone is interested
#61
Okay i started this for the 2007 2.2 motors only because theres a few things i wanna talk to you guys about.
i see so much stuff from other models thats usless to me.
um i forget your user name but its 06 something, your the one who said your car is a 2007 but you got it in 2006.
i see you have cams, i thoguth you can not but cams for the 2007 2.2? i tried to get them at one point and when they found out mine was a 2007 they said you cant.
and witch egale crank did you go with?
i tuned my car with the terifca tune but its only good to 10 PSI of boost.
i have a T4 flange turbo thats HUGE and i wanna run like 20 PSI
#62
i have cams stg 2 cams for the 07 FOR SALE!!! they have the cam sensor on them....custom made....they are comp cams with the cam sensor pressed on....the only ones you will find and im selling them at a great price
#64
here is there site
http://carputing.tripod.com/LS2main.htm
#65
I believe he got that crank from a cavalier forum, as far as I know they don't make them anymore.
Since when does trifecta only tune for 10 psi or boost and lower? I've seen some of his customers do 12+.
As far as your turbo, t4 is huge. What kind of turbo is it? That thing probably wasn't intended for such a small engine as ours.
Did you get your cams yet? I can't remember when they shipped out, seems like maybe Wednesday or Thursday.
Can't wait to see that monster up and running.
GT2860RS Kit
Clutch/Flywheel
Stage 2 Axles
75 Shot Nitrous
GT2860RS Kit
Clutch/Flywheel
Stage 2 Axles
75 Shot Nitrous
You must be a manual huh?
#66
IHI RHC7 turbocharger from GReddy turbo kit
alot of RX7 and Supra Guys run this turbo, and make well over 800 whp
Has the dual port exhaust in it and man this baby is HUGE!!!
Vince said the max somone is running on his tune is 13PSI
but he only recomended 10 psi, i was told 10 PSI on my turbo is looking at 420ish whp
#67
If you do plan on running that thing, make sure you go forged, or it will be the shortest 1/4 in your life.
#68
#69
#70
ya the cams that i have are the turbo grind ones made by Comp Cams. what would have to be done is take the cam sensor off the oem cam and press it to fit on the new cam. bridifi had sent his to bates engineering to do this and then sold it to mr.silent13.
o and the crank is the Eagle crank with timing ring
#72
In all honesty though, I'd rather keep my insurance low and have a balt quicker than a stg 2 for less.
As far as buying a different car, which I'm assuming that's where you were taking this, I bought this car for 15k new, and there's no way I'm going to trade in and take 5k or less. It would make no sense to sell this car unless I had to.
#73
#74
the turbo is between a gt40 and a gt42 in size but spolls like a gt30
Perfect thanks!
i am glad i started this post!
the motor inmy car is being pulled here in about a week or sooner!
so this help from you guys is great!
#75
http://www.driveshaftshop.com/
there is also a shop back in michigan that rebuilds automatics for race prep. I.E. billet trany. they said the automatics they rebuild will handle 1,000 ft/lbs at the gear box no problem. ($1,800 and includes pulling and replacing your trany)
And i know of another shop that will make you a custom trq converter and stall converter if you want to get serious about it..
ive been doing a lot of home work and not many people know that i was looking into all of this stuff.
