TVS 2.9 belt slip
Old 03-08-2016 | 09:11 PM
jdbaugh1's Avatar
TVS 2.9 belt slip
I have the ZZP 5 rib belt routing which utilizes stock L61 belt driven components. It's not quite cutting it in the higher RPMs. What's the best way to upgrade? Buy LSJ components and switch to LSJ 6 rib?
Old 03-08-2016 | 09:54 PM
06blackbalt's Avatar
what belt do you have?
Old 03-08-2016 | 10:17 PM
jdbaugh1's Avatar
Not sure. It is the belt that came with zzp supercharger kit and just adds an idler pulley and spaces out the alternator. I think thewafflesareburnt has the same belt routing in his recent post
Old 03-08-2016 | 11:59 PM
i would switch to the lsj belt. i ran it on a 2.8 without issues on a TVS, hell ran it on a 2.7 m62 without issue either
Old 03-09-2016 | 09:57 AM
jdbaugh1's Avatar
Stock LSJ Air Intake
Stock LSJ Tensioner
Stock LSJ Idler Pulley
Stock LSJ Alternator Bracket
Copied this from another thread. Is this everything I need to complete the swap?
Old 03-09-2016 | 01:00 PM
CobaltSS 16's Avatar
I have a GM Stage 2 belt for sale. Ran it on my ported M62 2.7" no problems.
Old 03-09-2016 | 02:23 PM
Staged07SS's Avatar
Administrator
Administrator
I ran down to a 2.75" pulley on my GMS2 belt.
Never had an issue.
Old 03-09-2016 | 02:52 PM
jdbaugh1's Avatar
What all parts do I need for the swap?
Old 03-09-2016 | 03:40 PM
All you need to do is get a GMS2 belt an carefully cut a rib off that is what i did on my old 2.2 with a 2.7 pulley
and it never slipped wouldn't hurt to get the oversized tensioner pulley also.
Old 03-09-2016 | 04:52 PM
jdbaugh1's Avatar
My belt slip is happening above 7,000 rpm. I have a 5 rib setup installed right now. Where do you get oversized tensioner pulley?
Old 03-10-2016 | 02:17 PM
jdbaugh1's Avatar
Those of you running an LSJ GMS2 belt with 1 removed rib what all components did you have to swap out? Just the tensioner assembly from LSJ?
What about the idler pulley from LSJ? Anyone know the part number on this?
Old 03-11-2016 | 04:51 PM
oversized tensioner pulley is un needed
Old 03-11-2016 | 04:53 PM
07blackg5's Avatar
Slobodan Milošević
personally, I chose so do a full 6 rib conversion. A big more cost and effort, but well worth it
Old 03-11-2016 | 05:11 PM
jdbaugh1's Avatar
Does the LSJ crank/harmonic balancer work on our motors?
Old 03-11-2016 | 05:12 PM
07blackg5's Avatar
Slobodan Milošević
yes, they are interchangeable
Old 03-11-2016 | 05:23 PM
07blackg5's Avatar
Slobodan Milošević
completely forgot to mention that if you do a full lsj swap, you will need to trim/grind off the bosses for the engine lift point on the front passenger side of the head. They need to be clearanced because the tensioner assembly hits.
I know this to be 100% fact on 07-08, but not sure on 05-06.
Old 03-11-2016 | 05:33 PM
jdbaugh1's Avatar
I remember seeing that when I was first researching SC builds. Thanks for the heads up.
jrsmith
12-06-2023 03:31 PM
Brandon Clement
02-05-2017 07:41 PM
Foximus
03-14-2016 11:15 AM
tamadrummer
03-08-2016 01:50 PM
cavfiredesire
03-01-2016 09:24 PM
Quick Reply: TVS 2.9 belt slip
