Tvs1320 l61?
07blackg5 (02-18-2016)
yes i run one with vx220
makes around 350 constant hp but does suffer with heat issues probably because of the engine being in the rear
it has made 380 hp peak power WITH COOL INLET TEMPS
running a 3.1 pulley
jdbaugh1 (02-18-2016)
I am only really shooting for around 300 whp when I get built. I wouldn't think I would have heat problems running it that easy? Is there a bigger pulley available for it?
Am I crazy to think I can run this de-tuned (highly retarded timing) before I go built?
yeah. i dont think theres a thread on it because i dont think its ever been done. I know i could do it but it comes down to trial and error when little **** goes wrong because no one will be able to help you. I have an LE5 swapped into my l61 car, but it was originally 07. Idk if the 05-06 bcm/internal car electronics are the same or not.
To build the bottom end do I need any special tools or fabrication? Is it easiest just to go stock bore? Do I just swap the parts out or is it more involved than that?
What all do I need?
-Valve springs
-Head studs?
-Con rods
-Pistons
Anything else?
well definitely do a lot of research on what you need and what it takes before jumping into it. look through that thread i posted, maybe take a class at community college.
expect to be buying a lot of tools
It's looking like my best bet is going to be going built and installing TVS all in one shot. It is going to hurt the bank but I would rather do that then have to fool around with swapping ECMs if I can get away with it.
What all do I need?
-Valve springs
-Head studs?
-Con rods
-Pistons
Anything else?
What all do I need?
-Valve springs
-Head studs?
-Con rods
-Pistons
Anything else?
I saw in your other thread that you are currently m62. Did trifecta originally tune you? You may be able to talk them into re-tuning, but that would be the first step. You are dead in the water without lining up a tune or exploring ecu swap/standalone options
