Update on my car! PICS!
Yeah i was planning on paiting it black. as for the LTFT's and STFT's i gotta check on that. im going to look into getting the replacement engine mount from TTR and use the TD also. so we'll see how that goes.
ok. at idle LTFT jumps between -9.4 and -10.2 STFT alterantes from 0.8 through -3.1 At WOT LTFT sits around -6.2 and STFT at 0. Hope that helps
Thank you
Soon. Im wating for one last part. a corsa touring for the ss/sc. Unfortunately that probably won't be in till after xmas.
For those who don't know this reading is for fuel richness or leaness (sp).
Thank you
my LTFT's are jumping between +10-+18 at WOT and STFT's half of that, looks like I'm going back to the 2.2 mani.
#36
#38
stock was about the same as yours are with the 2.4 mani.
that evap tap on the 2.4 mani I have is broken and I can't get it to seal right or get a replacement piece so I just put the 2.2 mani back on for the time being.
#40
i don't have any pics
just go look to the immediate left of your MAP sensor on the manifold and that nipple that sits at about 45 degree angle is what I'm talkin about.
has a tube that connects to it and then the other end connects to a piece to the immediate right of your ignition control module.
#42
on the 2.4 mani you may have to do that
on the 2.2 mani its just held in by a small screw.
just look at your manifold right above the throttle body and you'll see what I'm talkin about.
#46
Hey kano post some pics in the official sandstone metallic thread:
https://www.cobaltss.net/forums/pictures-videos-64/official-sandstone-metallic-thread-87316/
