Ut Oh is this bad
Ut Oh is this bad
So if i really floor it, im an auto, between first and second, like right before it shifts to 2nd i hear like a slight squeal or whine...is this bad? any ideas thanks guys! and this only happens in first never any other gear!
I get that too, I think its just the transmission mounts squeeling because they're not used to shifting so hard. I wouldn't worry about it. Then again I wouldn't be manually shifting it from L to I to D all the time, but thats another story.
been doing this for 40k miles and my trans and mounts are fine
Is it like a grindin noise? cause usually when i shift from 3rd to 4th i get a grind sound like im missing the gear but im not it goes in gear just has a grind right before it slides in
definatly not spun tires it really just sounds exactly like when u miss a gear and it grinds but im not missing the gear cuz it doesnt over rev or nothing just grinds for a short second then its done. usually only when im trying to slam through gears like if i shift to quick or hard.
Easy answer, you can't compare apples to oranges, they are differant.
