Vash90909's first build!
Old 02-24-2011, 07:26 PM
heathkidder's Avatar
i have stock 1 gauge pods one stock one black with one aftermarket boost/vaccum gauge and the other with stock ss gauge
Old 02-25-2011, 05:12 PM
vash90909's Avatar
ok...why are you posting this here?
Old 02-25-2011, 05:15 PM
vash90909's Avatar
I'll begin my install possible saturday night. Going to need to have everything done except the TB and wiring for it come sunday night if i'm going to have this running monday night. Only problem i'm facing is getting the air out of the cooling system for both the engine and intercooler and wiring the TB before I go to bed since I work early Tuesday. We shall see.
Old 02-25-2011, 05:16 PM
elecblue06's Avatar
good luck man
Old 02-25-2011, 11:08 PM
Mr.N00bLaR's Avatar
Good luck, have your internets handy!
Old 02-26-2011, 12:04 AM
vash90909's Avatar
Thanks everyone. This is going to be epic!
Old 02-26-2011, 12:18 AM
BlackCobalt707's Avatar
make that baby whine
Old 02-27-2011, 10:07 AM
vash90909's Avatar
Ok, well more sad news of delay. I had to help my grandmother move yesterday and today which isn't a bad thing but with work the cobalt is pushed back. Can't complain tho, this way I can make sure monday i recieve the right parts and I can finish painting the supercharger and Redoing the valve cover.
Old 02-27-2011, 10:22 AM
Tcobalt421's Avatar
good luck, ***** gunna be mean when your done!
Old 02-28-2011, 07:45 PM
vash90909's Avatar
TB is in and connector so I'm good on parts. Think I'm starting tomorrow after work and slowly do it each night, finishing Thursday or Friday. Got a spare vehicle to use so no rush needed. Let u know tomorrow!
Old 03-07-2011, 07:55 AM
  #36
vash90909's Avatar
Ok so zzp supercharger kit doesn't have a any tank for coolant for the intercooler/heat exchanger. Question is how to I fill and monitor this. It has a dual pass endplate, s3 exchanger, and pump. Do I just run the top and bottom nipple from the intercooler together to the pump to the top of the exchanger. Then the bottom of pump to middle nipple of intercooler? How do I fill?
Old 03-07-2011, 07:50 PM
  #37
vash90909's Avatar
Anyone?
Old 03-10-2011, 10:49 PM
  #38
vash90909's Avatar
Well took off the bumper, headlights, alternator and belt, and the intake system. Tomorrow will be the install!
Old 03-11-2011, 06:36 PM
  #39
vash90909's Avatar
Alright update time. Well the kit didnt come with everything needed so three trips later I finally have most the kit on. Done for the day. Need to finish setting up the hoses for the endplate, install supercharger, wire in throttle body sensor, hook up the filter and maf, install belt and bleed air out. Should be running tomorrow afternoon! Hope vince can tune on Saturday!
Old 03-12-2011, 03:54 PM
  #40
vash90909's Avatar
ok everything is installed but when i turn on the key my info says engine power reduced, engine disabled. Trying to figure it out, hoping it isn't the TB wiring. I followed this.
https://www.cobaltss.net/forums/2-2l...dy-l61-157541/
Old 03-12-2011, 04:01 PM
  #41
vash90909's Avatar
fuel pump isn't even turning on...i checked the codes it is throwing and two of them are about the throttle position so i'm assuming something isn't right there...taking a look. any ideas?
Old 03-12-2011, 04:05 PM
  #42
1LowLS's Avatar
Check the fuel pump relay and fuse.Maybe the TB wiring is wrong and causing the ECU to not command the pump on?
Old 03-12-2011, 04:10 PM
  #43
conerboner's Avatar
I know it's not the same but when I did my turbo install I wired the intercooler pump to the fuse panel and it was drawing too much voltage from the throttle body to get it to close to the idle position when you start it. I had three codes that were about the throttle position
Old 03-12-2011, 04:31 PM
  #44
vash90909's Avatar
i switched wires around that i found on a build thread on another site...now fuel pump turns on but the moment i started the car it revved up so i shut it off...
Pin A (Dark Green): TP Sensor 1 Signal
Pin B (Light Blue/Black): 5-Volt Ref 2
Pin C (Black): Low Reference
Pin D (Purple): TP Sensor 2 Signal
Pin E (Yellow): TAC Motor control 1
Pin F (Brown): TAC Motor control 2
Pin G (Gray): 5-Volt Ref 1
Pin H (Black/White): Low Reference
6-Pin
Pin A (Brown): TAC Motor control 2
Pin B (Yellow): TAC Motor control 1
Pin C (Tan): Low Reference
Pin D (Dark Green): TP Sensor 1 Signal
Pin E (Gray): 5-Volt Reference
Pin F (Purple): TP Sensor 2 Signal
I don't have light blue/black...or black/white
Old 03-12-2011, 04:34 PM
  #45
Spanky's Monkey's Avatar
i'd check the wiring on the tb. i got that dic warning on my turbo build. but i did forget to plug the harness in, either way sounds like you have some sorta short.
and welcome to the tuner world where the builds are always "epic" and the bullshit never ends.....lol.
Old 03-12-2011, 04:35 PM
  #46
6-Pin
how high were the rpms when it revved?
Old 03-12-2011, 04:38 PM
  #47
vash90909's Avatar
no idea i killed it right away...and now i have reduced engine power and engine disabled again....wtf
Old 03-12-2011, 04:44 PM
  #48
go back to the beck diagram and get a voltage checker to make sure you're getting the porper voltage. in your wiring.
that other diagram is apparently not for the cobalt.
Old 03-12-2011, 04:49 PM
  #49
1LowLS's Avatar
I wish I was home,I have the diagram that I used for 6 pin to 8 pin lsj wih no problems exept I did the same thing spanky did with the IC pump and it did the same thing.I now have the IC pump wired to the driving lights
Old 03-12-2011, 05:11 PM
  #50
vash90909's Avatar
ok i made my own diagram of my pin outs since the colors where not the same as oem but everything is wired up right...now i'm confused. After i turned it off it went back into limp mode...ganna delete the codes and see again.
Quick Reply: Vash90909's first build!
