Vash90909's first build!
I'll begin my install possible saturday night. Going to need to have everything done except the TB and wiring for it come sunday night if i'm going to have this running monday night. Only problem i'm facing is getting the air out of the cooling system for both the engine and intercooler and wiring the TB before I go to bed since I work early Tuesday. We shall see.
Ok, well more sad news of delay. I had to help my grandmother move yesterday and today which isn't a bad thing but with work the cobalt is pushed back. Can't complain tho, this way I can make sure monday i recieve the right parts and I can finish painting the supercharger and Redoing the valve cover.
TB is in and connector so I'm good on parts. Think I'm starting tomorrow after work and slowly do it each night, finishing Thursday or Friday. Got a spare vehicle to use so no rush needed. Let u know tomorrow!
#36
Ok so zzp supercharger kit doesn't have a any tank for coolant for the intercooler/heat exchanger. Question is how to I fill and monitor this. It has a dual pass endplate, s3 exchanger, and pump. Do I just run the top and bottom nipple from the intercooler together to the pump to the top of the exchanger. Then the bottom of pump to middle nipple of intercooler? How do I fill?
#39
Alright update time. Well the kit didnt come with everything needed so three trips later I finally have most the kit on. Done for the day. Need to finish setting up the hoses for the endplate, install supercharger, wire in throttle body sensor, hook up the filter and maf, install belt and bleed air out. Should be running tomorrow afternoon! Hope vince can tune on Saturday!
#40
ok everything is installed but when i turn on the key my info says engine power reduced, engine disabled. Trying to figure it out, hoping it isn't the TB wiring. I followed this.
https://www.cobaltss.net/forums/2-2l...dy-l61-157541/
#41
fuel pump isn't even turning on...i checked the codes it is throwing and two of them are about the throttle position so i'm assuming something isn't right there...taking a look. any ideas?
#43
I know it's not the same but when I did my turbo install I wired the intercooler pump to the fuse panel and it was drawing too much voltage from the throttle body to get it to close to the idle position when you start it. I had three codes that were about the throttle position
#44
i switched wires around that i found on a build thread on another site...now fuel pump turns on but the moment i started the car it revved up so i shut it off...
Pin A (Dark Green): TP Sensor 1 Signal
Pin B (Light Blue/Black): 5-Volt Ref 2
Pin C (Black): Low Reference
Pin D (Purple): TP Sensor 2 Signal
Pin E (Yellow): TAC Motor control 1
Pin F (Brown): TAC Motor control 2
Pin G (Gray): 5-Volt Ref 1
Pin H (Black/White): Low Reference
6-Pin
Pin A (Brown): TAC Motor control 2
Pin B (Yellow): TAC Motor control 1
Pin C (Tan): Low Reference
Pin D (Dark Green): TP Sensor 1 Signal
Pin E (Gray): 5-Volt Reference
Pin F (Purple): TP Sensor 2 Signal
I don't have light blue/black...or black/white
6-Pin
#46
6-Pin
6-Pin
#49
I wish I was home,I have the diagram that I used for 6 pin to 8 pin lsj wih no problems exept I did the same thing spanky did with the IC pump and it did the same thing.I now have the IC pump wired to the driving lights
#50
ok i made my own diagram of my pin outs since the colors where not the same as oem but everything is wired up right...now i'm confused. After i turned it off it went back into limp mode...ganna delete the codes and see again.
