Vash90909's first build!
Old 03-12-2011, 05:19 PM
  #51
Spanky's Monkey's Avatar
hope you get this straightened out cause you should be enjoying boost, not zzps bullshit customer service or the headaches of a build gone wrong. you're in my prayers bro.
Old 03-12-2011, 05:26 PM
  #52
vash90909's Avatar
ok it starts now but it goes straight to the rev limiter...can't figure it out
Old 03-12-2011, 05:32 PM
  #53
sounds like a vacuum leak if your elec work is right now.
Old 03-12-2011, 05:47 PM
  #54
vash90909's Avatar
Put from what...what vacuum leak could cause it to go to 6.5k rpm
Old 03-12-2011, 05:53 PM
  #55
i couldn't tell what leak can cause that but you either have the 5v signals mis-wired or you have a vac leak. sorry i cant be of more help.
Old 03-12-2011, 05:56 PM
  #56
1LowLS's Avatar
sounds like you have 2wires crossed on the TB.sounds like the TB is staying open when it needs to be shut
I noticed that one of the diagrams on here was different from mine.2 wires were diferent
Old 03-12-2011, 06:29 PM
  #57
vash90909's Avatar
Can u look at your wiring?
Old 03-12-2011, 06:32 PM
  #58
1LowLS's Avatar
actually i posted the diagrm on another thread.let me find it
Old 03-12-2011, 06:36 PM
  #59
1LowLS's Avatar
connect green to green
yellow to yellow
tan to black/white to black,so black/white and black on the 8 pin get tied together to tan on the 6 pin.
dark green to dark green
grey to grey and light blue/black.so grey on the 6 pin to grey and light blue/black on the 8 pin
Then purple to purple
Old 03-12-2011, 06:44 PM
  #60
vash90909's Avatar
I believe that's how I have it, I can look tomorrow I'm going out for the night. I emailed vince too.
Old 03-12-2011, 06:46 PM
  #61
1LowLS's Avatar
Cool cool.Make sure you have sensors in both map sensor holes too.I remember I left the top sensor in the blower out and it did that
Old 03-12-2011, 07:37 PM
  #62
vash90909's Avatar
Zzp kit has them blocked off. The map is hooked up to the small barb on the top of the manifold near the fuel rail. U use a vacuum line to install map
Old 03-12-2011, 08:16 PM
  #63
1LowLS's Avatar
WTH?the small barb is for boost gauge.Theres a hole on the left of the intake manifold next to the blower where the map should go
Number 711 thats where the map goes.
Old 03-12-2011, 08:19 PM
  #64
corn gas ftw....
ssblackstealth's Avatar
congrats man, its gunna be fun!
Old 03-12-2011, 09:46 PM
  #65
vash90909's Avatar
That is how zzp hooks it up for their kit. they block off the map hole and the hold on the supercharger.
Old 03-12-2011, 09:56 PM
  #66
vash90909's Avatar
What has me so confused is my 8pin connector does not have the same colors but I followed the pin out diagram and wired that way.
Old 03-13-2011, 12:54 AM
  #67
vash90909's Avatar
Ok update...according to gene's diagram I'm wrong with my wires so solution I think I found you. can't wait to wake up!
Old 03-13-2011, 10:09 AM
  #68
vash90909's Avatar
She runs now! only problem is she is running very rich. I'm ganna data log for vince as soon as be is ready.
Old 03-13-2011, 10:14 AM
  #69
huckernage's Avatar
nice.
Old 03-13-2011, 12:07 PM
  #70
conerboner's Avatar
Woot get a video!
Old 03-13-2011, 12:15 PM
  #71
vinces tunes always run rich. you gotta work with him on getting it dialed in so you can lean her out.
Old 03-13-2011, 12:17 PM
  #72
kxrida2000's Avatar
so wat tb wiring diagram did u use that was right?
Old 03-13-2011, 12:20 PM
  #73
conerboner's Avatar
kxrida you should update your sig it says soon to be turbo lol
Old 03-13-2011, 12:22 PM
  #74
1LowLS's Avatar
Just sayin the one I posted is the one thats been running on my car since day one with no probs...just sayin
Old 03-13-2011, 12:23 PM
  #75
good point.
Quick Reply: Vash90909's first build!
