Vash90909's first build!
#114
With the way it is wired right now when i start it, the engine shoots to the rev limiter. I had solved this problem yetsterday. It idled nice and smooth but the AFR was WAY off...vince said the TB is wired wrong that is the cause...so now i'm trying to rewiring to get the idle smooth and the AFR right.
#115
wire it how you had it when it was idleing good then swap the 2 that say tp signal 1 and 2.it sounds like the actuator circuit was wired correctly but the throttle posistion was backwards.other than I dunno
#118
I dont know if this is any different
6pin/8pin
A--->F
B--->E
C--->H+C
D--->A
E--->B+G
F--->D
the diagram looks right but the colors are not.I know for sure there is tan to black/white to black
He also has A to E and B to F.Thats backwards
I dunno try em all lol.I dont know why how mine is doesnt work on yours.
6pin/8pin
A--->F
B--->E
C--->H+C
D--->A
E--->B+G
F--->D
#119
then how is his running? I know his diagram doesn't work on mine...I'll rewire it like you just posted later tonight or tomorrow. Right now i need a break before i go and take it all off and make a for sale thread. LOL
#122
Ok round three...well day three. going to try this.
green - a
gray - b, g
tan - c, h
purple - d
yellow - e
brown - f
that's how I wired it when I had it running. ill work from there.
green - a
gray - b, g
tan - c, h
purple - d
yellow - e
brown - f
#123
Ok that gets it running and it stays at 1100ish for idle. Try to give it gas and it stumbles a bit but does go up. When the rpms are going back down it goes below idle and comes back up. ARF is at 10 or below...so back to how it was before.
