Vash90909's first build!
#126
ok that threws the TB idle speed code for the engine...and puts in reduced power...so yellow and brown are not the cause. Next step is the TB potition signal which is Green and Purple.
#127
ok, switching Purple and Green caused it to threw engine disabled so that can't be the problem. Switched them back and deleted codes and started up and back to before. Idle stays where it should but WAY to much fuel. I can smell it...
#128
ganna leave it like it is and call vince at noon(est) and see what he says. This way i have it wired throws no codes and it starts up nice. He said the TB was wired wrong but really i've tried just about EVERYTHING with this wiring.
#141
lol, thanks. Me and vince are working on the tune. What happened was the tune wasn't being accepted for some reason. A few tunes and updates later we are idling smooth(to rich still) but the black smoke and fuel small is almost gone. PLus i'm finally seeing 11-1 at idle...closer!
#145
thank you all so much, the next meet in or around PA im there! need to keep working on the tune alittle more...still havent seen even half throttle...or the road for that matter. soon tho. Right now i'm install headers on my buddy's 4.7 Ram
#146
It runs and drives, vince said the 60# can't run much more lean at idle due to the lack of fuel demand and them being so big. He is ganna turn them down just a hair more to help it out. Part throttle is running good, half throttle is alittle to lean, WOT is still to rich but not by much. Haven't really been able to see much boost due to data logging and being safe but DAMM, BOOST IS FUN!!!
