vibrant hdr/dp no gasket?
Nothing against you, I found this on the MangaFlow website..
"To reduce additional backpressure, the OEM exhaust tubing can be replaced with madrel-bent tubing of the same size or one size up from the OEM. As a general rule, you can enlarge the pipe diameter of your OEM exhaust system by 1/4- to 1/2-inch to increase your horsepower. However, any additional increase in pipe diameter is likely to decrease your performance; specifically, low end torque.
Bigger is not always better."
On a cat-back, a bit bigger won't hurt AS bad.. But the primaries on an exhaust manifold are just a little more important.
Just my 2˘
Just my 2˘
Just my 2˘
Just my 2˘
09-28-2015 12:51 PM
Macgyver2484
09-02-2015 05:44 PM
