wanna build my 2.2 up for more boost!
#287
woot it's alive! afr was in the 16s at idle but i broke the v band on the exhaust so that could be why it's reading off. I was so scared to start it and then it just started like it did before i took it apart and it felt great! All I have to do tomorrow is bleed the clutch and put the bumper and hood back on and test drive it
#292
Looking good, I believe werks did my first oil change at like 15 miles, conventional oil, might be something you want to do. I'm doing second one at 1000 and changing to Mobil 1
#294
This is how I do oil changes on fresh motors. Intial start I always use conventional oil over synthetic its cheaper. I start it let it run for 30 minutes change the oil. 15 miles change, 50 miles change 100 change, 500 change, 1000 change, 3000 change. It hasn't failed yet.
#297
Seems a little redundant no? But I guess it wont ever fail.
Gotta make sure the rings sit properly too if you're putting in new pistons which I would never let it sit and run for 30 mins.
I changed my non detergent oil at 500 miles. Then went back to synthetic.
#298
My uncle is an engine builder, ive built 3 motors personally including the 2.2 in my cobalt, and i know 4 guys with machine shops and every motor they build is broken in the same amount of time. Last one was a 540 bbc that will be dynoed in the car this week and should be over the 1800+ hp amount easily.
