wanna build my 2.2 up for more boost!
Old 04-28-2011, 10:50 PM
  #451
Spanky's Monkey's Avatar
Originally Posted by Tundraboarder666
Guys having trouble top end with the misfiring PLEASE CHIME IN!
I'm talking to Vince right now about this issue, He wants to know what spark plugs you're running at what gap, when it's happening in the RPM range and what the AFR's look like when it happens.
Thanks!
i had it at 6k and 15 a/f ratio, of course I backed off the second I saw the a/f.
Old 04-29-2011, 12:09 AM
  #452
conerboner's Avatar
yep mines' doing it at 6000 rpms with the autolites and even with the ngks
I'm ready to start changing coil packs and all kinds of ****.
Old 04-29-2011, 12:10 AM
  #453
Brags's Avatar
Get the ngk Spanky, from what ice been reading and hearing, if your
Old 04-29-2011, 12:11 AM
  #454
Brags's Avatar
Not running stock, anything but ngk run at own risk
Old 04-29-2011, 12:46 AM
  #455
Tundraboarder666's Avatar
I'm about ready to do the same.
Old 04-29-2011, 01:12 AM
  #456
conerboner's Avatar
I'm reading up on it and there's so many things it can be. ugh
Old 04-29-2011, 01:25 AM
  #457
Brags's Avatar
I had coilpack go out in three, it would misfire Like crazy at bout 5500 in third everytime.
Old 04-29-2011, 01:27 AM
  #458
conerboner's Avatar
did you throw a code for it? The problem with mine is it's random so i don't know which one is bad or if it is a coil pack or wtf is going on
Old 04-29-2011, 01:32 AM
  #459
Brags's Avatar
I was getting p0171, p0172 and sometimes p0101 I think, u could tell by plug in three. It was black. Regapped tighter? And replced coilpack much better. But honestly best thing was switching to recirculated bov
Old 04-29-2011, 02:21 AM
  #460
Mine always goes off in 2nd gear around 6500 RPMS on my 13 PSI tune... Now that I'm pushing 20 PSI it always goes off. I'm recirculated as well still no dice...
Old 04-29-2011, 11:49 AM
  #461
Brags's Avatar
Do you have recirculated dump tube or BOV? Check the coilpacks, I was at 60000 miles when mine went out, dont know how many miles u guys have
Old 04-29-2011, 11:57 AM
  #462
BoV. I'm at 53,000. I'll have to check them.
Old 04-29-2011, 12:19 PM
  #463
Brags's Avatar
Ok cool, yeah I would check the coil packs, fyi 2.4 solstice are the same. I got lucky and Werks works on those alll the time, so had a ton sitting around
Old 04-29-2011, 12:40 PM
  #464
conerboner's Avatar
i'm at 61000 but how do i know which one is bad? the code said random/multiple cylinder misfire... should I gap my plugs to .026 or leave them at .028?
Old 04-29-2011, 12:46 PM
  #465
There's a tool you can use to do it but Idk if I trust it... Probably just play with the screwdriver with a thick rubber handle LOL. Anyone else have a better way of checking them?
Old 04-29-2011, 12:51 PM
  #466
Brags's Avatar
On mine you could tell by the plugs, number three was black, the others were normal greyish red.
Old 04-29-2011, 12:54 PM
  #467
All of mine are black... lol
Old 04-29-2011, 04:43 PM
  #468
Brags's Avatar
Def check your coil packs lol
Old 04-29-2011, 07:11 PM
  #469
kxrida2000's Avatar
no dont go lower than .028
Old 04-30-2011, 12:18 PM
  #470
parting out the car if anyone needs an engine, trans or turbo kit. got put in a real bad spot.
Old 04-30-2011, 02:58 PM
  #471
God damn... It is a sad day in the 2.2 community
Sorry to hear bud. I really hope you guys are able to find jobs soon and get back on your feet!
Old 04-30-2011, 06:56 PM
  #472
conerboner's Avatar
Damn spanky I'm sorry you have to go through that. I'm going to replace my fuel filter money and add some fuel additive and see if that helps the misfire problem. Vince said the logs look like my fuel pump isn't keeping up
Old 04-30-2011, 11:50 PM
  #473
my coabalt has the lsj fuel pump on it and i'm still seeing spark knock up top. i have the interceptor with a fuel pressure sensor and it's not losing fueling so that's not the issue. it my be plugs in my case. as for the icm, i had one go bad after about 60k. mind you that icm had seen a lot of wot high rpm pulls and some serious nitrous use. cost me $100 brand new to replace so it wasn't that bad.
hell come to think of it coner if you need an interceptor mine with the fuel pressure sensor might not be a bad investment.
Old 05-01-2011, 12:48 AM
  #474
conerboner's Avatar
The weird thing is it doesn't do it on a full tank. I'm hoping the fuel filter will help
Old 05-01-2011, 09:47 PM
  #475
Brags's Avatar
How things coming coner any progress? Are you and tundra on stock fuel pump?
Quick Reply: wanna build my 2.2 up for more boost!
