wanna build my 2.2 up for more boost!
honestly if u want a suggestion take mine especially since we have the same turbo mine just has a bit more pull up top. But my suggestion is 8.9:1 due to it being safer and it daily drives just fine.. if u want to talk ricer numbers my 60-100 is 3.8-3.9 seconds so she has some ***** without a doubt and thats low compression so i have all the torque i need
Kx your right most due but do you understand why? Its not because you have to in order to run a large amount of boost, its for safety reasons. Its parts of the reason most factory forced induction come with low compression stock. Its all centered around the limitations of your tune and fuel, low compression allows you to run more boost and more timing with a larger safety net in case of knock on pump gas. When we through alternative fuels into the mix though alot of this can be thrown out the window, e85 and hybrid pump/race gas mixes change the game. There is logic behind both. Its all personal preference for the cards you are dealt.
That's exactly what I said(ie. compresion difference), but you stated it wasn't made for boost and that statement was completely wrong.
#36
