wanna build my 2.2 up for more boost!
#526
cool thats what i was thinking, 89:1 I order them TODAY should have them monday or tuesday i got everything you told me to. Do i use stock bearing? so now tell me what size pulley should i use ? my car is a auto. one thing i do know is vince is the man .
#527
Yeah Vince is smart as ****. Make sure you get new rod bearings... Other than that you will be good! My car is auto too so we are in the same boat. If it's built then I'd say start with a 2.8 and see what you can do! You might want to pulley down later on, but I don't think you will be disappointed with the 2.8.
Though I have to ask what else do you have done to the car?
#528
I ported the head, put in zzp 78# vavle springs , header , and getting stage 1 1/2 cams from zzp . Zoom said that they where all most stage 2 cams and Vince tune it. thats it DO I GET ROD BEARING DEALER ?
#530
ok , and I also did a cat back to . so dont use stock bearing? one more thing with your auto tran is it still stock and doing fine ? would zzp have bearing ? because i have order pulley to going to do next
#531
Yeah get the upgraded rod bearings, they will die after a while and its something you might as well put in it while youre in there. It was doing fine until I started the build on it lol. I cracked the drum on it with the new clutches so Im looking for an aftermarket one right now or using the 4t65 internals. IDK if ZZP does or not you would have to check. Dont worry about the trans though it will be fine. you're not pushing the power levels on it yet.
#532
ok so don't buy stock bearing? i need to get them from turbo tech ? i just need to tell them it for a 08 L61 2.2 ? WHAT ABOUT THEY PULLEY IS OK OR DO I NEED TO GET IT FROM ZZP ?
#533
Aftermarket bearings broseph! I got mine from TTR
Clevite Rod Bearing Set Chevrolet Cavalier 2002-05 Cobalt 2005-10 2.2L Ecotec - Engine Internals - Turbo Tech Racing, LLC
Get a smaller pulley and let the boost flow! ZZP should have those for you.
#535
PLEASE do NOT get 10.1:1... plus boost, Unless you want to go BOOM! lol
Pulley down and get some some true potential out of that thing. Otherwise you will never be able to pulley down and will have to stick with that small amount of boost. I have the 8.9 to 1 in mine... Vince will help you make the right decision with this too.
takes power to make power, blowers like higher compression
BUT if you guys need a credible source, just check out what ZZP did on the M62.
https://www.cobaltss.net/forums/2-0l...pe-%3B-232636/
#536
he wont go boom on 10:1...besides theres no point in going lower than a 2.7 anyway. Any lower and hes just going to overspin the blower and generate massive amounts of heat. also to add to that, hes not going to be able to run a ton of boost to make up for that lack of compression.
#543
#545
good deal i get the upgraded bearing order today. and i'm order my pulley also do you think i be ok with a 2.7 on my auto tranny ? and can vince tune that CJ said that a 2.7 was hard to tune
