wanna build my 2.2 up for more boost!
Old 05-10-2011, 09:05 PM
  #526
gbkglenn's Avatar
cool thats what i was thinking, 89:1 I order them TODAY should have them monday or tuesday i got everything you told me to. Do i use stock bearing? so now tell me what size pulley should i use ? my car is a auto. one thing i do know is vince is the man .
Old 05-10-2011, 09:14 PM
  #527
Tundraboarder666's Avatar
Yeah Vince is smart as ****. Make sure you get new rod bearings... Other than that you will be good! My car is auto too so we are in the same boat. If it's built then I'd say start with a 2.8 and see what you can do! You might want to pulley down later on, but I don't think you will be disappointed with the 2.8.
Though I have to ask what else do you have done to the car?
Old 05-10-2011, 09:23 PM
  #528
gbkglenn's Avatar
I ported the head, put in zzp 78# vavle springs , header , and getting stage 1 1/2 cams from zzp . Zoom said that they where all most stage 2 cams and Vince tune it. thats it DO I GET ROD BEARING DEALER ?
Old 05-10-2011, 09:31 PM
  #529
Turbotechracing should have them.
Yeah Vince will tune the poop out of it!
Intake or exhaust?
Old 05-10-2011, 09:38 PM
  #530
gbkglenn's Avatar
ok , and I also did a cat back to . so dont use stock bearing? one more thing with your auto tran is it still stock and doing fine ? would zzp have bearing ? because i have order pulley to going to do next
Old 05-10-2011, 11:24 PM
  #531
Yeah get the upgraded rod bearings, they will die after a while and its something you might as well put in it while youre in there. It was doing fine until I started the build on it lol. I cracked the drum on it with the new clutches so Im looking for an aftermarket one right now or using the 4t65 internals. IDK if ZZP does or not you would have to check. Dont worry about the trans though it will be fine. you're not pushing the power levels on it yet.
Old 05-10-2011, 11:34 PM
  #532
gbkglenn's Avatar
ok so don't buy stock bearing? i need to get them from turbo tech ? i just need to tell them it for a 08 L61 2.2 ? WHAT ABOUT THEY PULLEY IS OK OR DO I NEED TO GET IT FROM ZZP ?
Old 05-10-2011, 11:41 PM
  #533
Aftermarket bearings broseph! I got mine from TTR
Clevite Rod Bearing Set Chevrolet Cavalier 2002-05 Cobalt 2005-10 2.2L Ecotec - Engine Internals - Turbo Tech Racing, LLC
Get a smaller pulley and let the boost flow! ZZP should have those for you.
Old 05-11-2011, 12:00 AM
  #534
gbkglenn's Avatar
good deal i saw them at TTR just make sure that was them . Thanks again for all your help i'll keep you posted Glenn
Old 05-11-2011, 04:15 AM
  #535
IonNinja's Avatar
Originally Posted by Tundraboarder666
PLEASE do NOT get 10.1:1... plus boost, Unless you want to go BOOM! lol
Pulley down and get some some true potential out of that thing. Otherwise you will never be able to pulley down and will have to stick with that small amount of boost. I have the 8.9 to 1 in mine... Vince will help you make the right decision with this too.
he wont go boom on 10:1...besides theres no point in going lower than a 2.7 anyway. Any lower and hes just going to overspin the blower and generate massive amounts of heat. also to add to that, hes not going to be able to run a ton of boost to make up for that lack of compression.
takes power to make power, blowers like higher compression
BUT if you guys need a credible source, just check out what ZZP did on the M62.
https://www.cobaltss.net/forums/2-0l...pe-%3B-232636/
Old 05-11-2011, 05:42 AM
  #536
Sw4y1313's Avatar
Agreed... If your just going to stick with the M62, I'd jump your compression up even more to 11 - 11.5 and run meth injection or E85 and pull some sick numbers like ZZP did. You could even run it on 93oct with a good tune. Just make sure you have the right cooling mods. Not saying you need every cooling mod out there, just the right ones. Do your research and you'd have the fastest m62 L61 out there.
Old 05-11-2011, 08:34 AM
  #537
conerboner's Avatar
And the stock bearings are fine just get new stock bearings from the dealer.
Old 05-11-2011, 08:45 AM
  #538
kxrida2000's Avatar
this...u dont need to waste all the cash on clevites like i did when i didnt know any better lol
Old 05-11-2011, 08:55 AM
  #539
conerboner's Avatar
Ooh look what i get to play with now lol
already ordered oem fog lights for it and it's getting tint today!
Old 05-11-2011, 09:00 AM
  #540
gbkglenn's Avatar
I like it what kind of car is this
Old 05-11-2011, 09:04 AM
  #541
conerboner's Avatar
2011 scion tC
Super White
6 speed manual
Old 05-11-2011, 11:29 AM
  #542
Brags's Avatar
Hey coner how's the clutch holding up? I'm the second in a month to hqve spec 3 go out in me
Old 05-11-2011, 12:43 PM
  #543
I'm trying to think of the guy who did go boom on the 10.1:1... He had a thread on it. Anyways You can go lower than a 2.7 ask Richie He gained a lot of torque going from the 2.7 to the 2.5. Yes you're going to be generating more heat, but if he has cooling mods then who cares... I drive on the 8.9s everyday he doesnt need to make boost to drive... And yes for sure run some e85!
Old 05-11-2011, 12:45 PM
  #544
Reason I say to buy the upgraded bearings is because Chris had his go out on him. He was a auto 2.2 with a m62 on a 2.8.
Old 05-11-2011, 01:21 PM
  #545
gbkglenn's Avatar
good deal i get the upgraded bearing order today. and i'm order my pulley also do you think i be ok with a 2.7 on my auto tranny ? and can vince tune that CJ said that a 2.7 was hard to tune
Old 05-11-2011, 01:40 PM
  #546
Same as anything else that's gonna be tuned... Your tranny will be fine dude! Just have vince max out the line pressure on the tranny.
Old 05-11-2011, 03:56 PM
  #547
gbkglenn's Avatar
ok thanks , you help keep me in line. on line now to buy pulley . which one stick with 2.8 or 2.7 ? this the last thing to get order
Old 05-11-2011, 11:01 PM
  #548
I'd go with the 2.7 if it were me.
Old 05-11-2011, 11:20 PM
  #549
1LowLS's Avatar
I havent been following but if your built do a 2.7.I would.Im on a 2.9 unbuilt right now
Old 05-11-2011, 11:23 PM
  #550
Yup he's built! Well... He will be built
Quick Reply: wanna build my 2.2 up for more boost!
