wanna build my 2.2 up for more boost!
#551
ok thanks i will get it order tomorrow. just what to spend it one time . i'm get bearing order to i saw the last post about the stock bearing. i'll keep you posted . ALSO IS MY STOCK BELT TENSIONER OK DO I NEED TO UPGRADE IT TO LIKE TO MAKE ONE ORDER.
#555
how high do you plan on reving this thing? because according to ZZP those stage 2 cams make peak power ~7800RPM. If you plan on taking it that high you need to take that into consideration when selecting your pulley size
#561
ok thanks ,a guy i no has a 07 i can get for $200. he not going to build. this way i can use this block it only have 10k on it and my car what have to sit at this shop i'm not that crazy about for 1 or 2 weeks. to many guys use it. do i need to do NBS from zzp I was told with new springs you can 7500 rpm , do you think i can sell my block
hope parts come in tues
#562
I'm back just what to give you guys a update, we got the engine out monday i carry it to the shop the same day . I just ck UPS and my pistons and rods will be here on wed. I hope to get it back by the end of next week. still wait on cams , and i need to order a 2.7 pulley and belt trying to get the right size belt. Thanks for the help you guy gave me . I'll keep you guys posted
#566
Spanky is still having prob with misfiring as well. Sucks you guys can't use hpt, ps mine was done on ls2edit which is available for you guys I believe.
#568
Quite possibly, mine wasn't running real good till after about 3 tuning sessions with it. And the first one was dyno and street with at least 20-25 pulls on dyno. It took a lot of adjusting to get it where its at now. Once my new clutch is broken in, I think I should be seeing around 350 whp, considering my Spec was slipping the whole time. Oh and ls2edit is just another tuning software, actually much more in depth than hpt. We originally were going to use hpt but there cable was having probs, and had ls2edit right there.
