wanna build my 2.2 up for more boost!
#651
Just got it back today: Clutchmasters FX 400, stock gm flywheel, Team Green LSD insert, Dunlop Direzza Star Specs, Motegi SP10 18x8, Gorilla black thin lugnuts. Got 90 miles on so far, time for driving.
#655
Anyone noticing hard cold starts with E85? I threw 3 gallons of 93 just to see if it helped with cold starts and it did so im wondering if my plugs are too cold for running E85.
#656
Do you guys think it could be the wiring for the fuel pump? maybe it got too hot and now it's shorting out from the aftermarket pump. I'm thinking this because my battery is dead now but it could be from it not running for a while and when it does run it doesn't run long enough to charge the battery up.
#661
yes the optimas are much better batteries and that may be ur whole issue is the battery. When i had a bad battery with my car running it idled funny and when i hooked up a battery charger on 40 amp the idle smoothed right out and when i would click it off the idle would go rough again.
#667
got this email from vince
Sounds like the +12V supply to the injectors has an intermittent problem.
could this be the battery? I'm on flood duty again so I can't really try anything but when I get home i'm gonna get an optima yellow top and see what happens. if that's not it i'm gonna get my alternator tested and see if that's bad
#671
Wow, I'm actually not doing half bad compared to everyone else at the moment... crazy. I'm getting HPTuned and it's so much better than running anything Vince ever did for me. Still can't go WOT yet though we never got around to tuning that before the battery on his laptop died. No misfires yet tho. And I've been hitting upto 19 PSI at half throttle and it feels great!
