wanna build my 2.2 up for more boost!
Old 06-30-2011, 01:11 PM
  #676
Tundraboarder666's Avatar
Originally Posted by Brags
For me pretty sure bearings are toast from lack of oil. Not positive yet, but think my return from turbo was backed up. Prob have a few quarts in my intercooler.
FUUUUUUUUCK I know my return has a very small leak... I've replaced the line before, but still doesn't seem to help out. My coolant line also has a leak now too Gonna have to fix that soon..
Old 07-07-2011, 08:08 PM
  #677
conerboner's Avatar
I'm gonna be home tomorrow so hopefully I can figure out what's wrong with mine!
Old 07-08-2011, 08:15 AM
  #678
kxrida2000's Avatar
How the hell would it have backed up that quickly?
Old 07-08-2011, 10:34 AM
  #679
Brags's Avatar
I don't know lol. Got oil change at werks week before, then I started hearing funny noise, check oil level. It was way low. Added 2 quarts and went to CED hotel. Did oil change when i got there(20 miles) and only 3 quarts drained out. And oil filter covered in shavings.
Old 07-08-2011, 12:57 PM
  #680
Wow... that's not good man... find out anything that could be wrong with it?
Old 07-09-2011, 09:45 AM
  #681
conerboner's Avatar
well i can't get my alternator off lol. the tensioner for the belt doesn't line up with the hole to release the tension on it. but the battery was completely dead so hopefully I can just get a new one and start it up no problems
Old 07-09-2011, 12:36 PM
  #682
Should work
Old 07-09-2011, 02:09 PM
  #683
Brags's Avatar
So far looking like only damage is to bearings, lucky i cqught it early. No for cause yet though, sad panda lol
Old 07-09-2011, 03:18 PM
  #684
conerboner's Avatar
Well i got a new battery and it fixed it
Old 07-09-2011, 03:26 PM
  #685
w00t Nice dude!
Old 07-09-2011, 03:58 PM
  #686
conerboner's Avatar
Yeah what a pita of course it was something easy
Old 07-09-2011, 04:11 PM
  #687
hey at least its fixed though
Old 07-09-2011, 04:45 PM
  #688
conerboner's Avatar
Yeah buddy! now i just need to put my foglights and 3000k hids in for my engagement pics tomorrow lol
Old 07-10-2011, 10:30 PM
  #689
Switt23's Avatar
So it sounds like I will be joining this group of frustrated 2.2L members soon .
Carrier bearing broke in my transmission last summer... cars lowered on SSC springs and 18"s and my dad had to drive the car and put it in a chuck hole which punched the half shaft into the transmission casing, cracking the bearing.
Car has driven perfectly fine for almost a year, it's just sounds like i have a bad wheel bearing to the 9th power .
Dude Brags... your car is what motivated me to finally tear down the transmission and boost the car. that's scary to see yours down already. Sounds like an oil leak or someone fell asleep on the job and filled with old oil. Typically the back of the bearings wear if you have bad/old/no oil. Glad you caught it though.
I will have to update later and create my own build thread to join the group
Old 07-11-2011, 04:26 AM
  #690
Welcome!
Old 07-14-2011, 08:00 AM
  #691
conerboner's Avatar
fml it's doing it again! Does the computer have to relearn or some stupid $hit? It only dies when I'm at low rpm's slowing down for a red light or something like that...
Old 07-14-2011, 09:55 AM
  #692
Switt23's Avatar
I would have your alternator tested if you haven't yet
Old 07-14-2011, 10:13 AM
  #693
conerboner's Avatar
Im gonna do that after work but i would think the new battery would already be shot if the alternator is bad
Old 07-14-2011, 11:50 AM
  #694
Brags's Avatar
Mine was def oil starvation, seems the return line from the turbo was backing up, no oil back to engine. Not positive yet but thats where were at. getting rid of AEM digital boost gauge ( never read accurate), reading boost on interceptor, and getting oil pressure gauge to better monitor situation. But Ill be back in action soon, no worries
Old 07-14-2011, 03:19 PM
  #695
Ugh that's no good... for the both of you... Still waiting on tuning next Monday to see if my car wont be a retard top end anymore. it could be because Vince had me on 17.5 degrees of timing and my car is knocking on anything above 11... lol
Old 07-14-2011, 05:34 PM
  #696
conerboner's Avatar
well the alternator tested out good so I have no idea what my problem is... Maybe I already need a new fuel filter? I'm going back to o'reillys to see if I can borrow a fuel pressure gauge and see what i'm at when idling. I'm about ready to buy a freakin honda lol.
Old 07-14-2011, 06:44 PM
  #697
Brags's Avatar
Coner I think you might have sQme prob I used to, if dying when come to a stop. Will it stay running if you give a little gas when it comes down to around 1000rpms? You might need recirculated bov like me and tundra. P.S. my crank is fucked up too, yeah
Old 07-14-2011, 10:18 PM
  #698
conerboner's Avatar
Yeah if i put it in neutral and use my left foot on the brake and feather the gas with my right i can usually keep it running. How hard is it to switch to recirc or do i just need a new bov?
Old 07-14-2011, 10:50 PM
  #699
Brags's Avatar
The way mine was done, I needed redone hot side to get it closer to intake you might not need that. New bov, hose to intake, and a bung on intake to take in the recirculated air. I'll try and find some before and after shots for u
Old 07-16-2011, 10:42 PM
  #700
Brags's Avatar
Here are a few before and after shots
Before: notice the bov way off to drives side
After: bov moved to middle, hose added goes in to intake now
Quick Reply: wanna build my 2.2 up for more boost!
