wanna build my 2.2 up for more boost!
Old 07-28-2011, 07:43 PM
  #726
conerboner's Avatar
at least i tried
Old 07-28-2011, 08:19 PM
  #727
Tundraboarder666's Avatar
Yeah think I might have to replace my TB... anyone have a spare 2.4 TB laying around?
Old 07-28-2011, 09:02 PM
  #728
IonNinja's Avatar
Originally Posted by Tundraboarder666
because then you have to bore...
don't you have to anyway to ensure that the rings seal properly against the cylinder walls?
Old 07-28-2011, 09:31 PM
  #729
Yes, but it's very minute compared to actually boring out the cylinder walls. Especially on stock sleeves which are set to fail at 400whp.
Old 07-28-2011, 10:20 PM
  #730
conerboner's Avatar
you just have to delaze them...
Old 07-29-2011, 10:13 AM
  #731
IonNinja's Avatar
I see...so whats the purpose of making pistons in an .020 overbore then?
Old 07-29-2011, 10:32 AM
  #732
1LowLS's Avatar
more displacement.if you order pistons with stock sleeves,you dont get an overbore.you just need to hone the cylinders out to get the glaze out.if you sleeve your block and bore it out is when you buy over bored pistons
Old 07-29-2011, 10:41 AM
  #733
kxrida2000's Avatar
bigger bore= more powa
but like others said on stock sleeves...bigger bore= booooom
Old 07-29-2011, 11:22 AM
  #734
Switt23's Avatar
Wanted your guys opinion...
Running an m62, stock internals... safe to push it to a 2.85? I had planned a 2.9" pulley as that's what others have beeen successful with. Not sure how much of a difference would even be seen.
Old 07-29-2011, 11:32 AM
  #735
1LowLS's Avatar
ya you'll be fine.just make sure the AFR's are good and you have all the cooling mods.Im on a 2.9 right now and **** cranks pretty good.
Old 07-29-2011, 12:25 PM
  #736
IonNinja's Avatar
Ah okay...I'm not very good at math but .020 doesn't seem like it would add very much displacement lol
Oh well ...now I know what to buy
Old 07-29-2011, 01:23 PM
  #737
It may not be a lot when you think about it a .020, but it does make quite a difference. Especially in cars as light as ours.
Old 07-29-2011, 05:26 PM
  #738
conerboner's Avatar
You can haz my 2.2 one lol
Old 07-29-2011, 06:14 PM
  #739
LOL I tested my 2.2 already. My TB isn't bad though. But thanks for the offer!
Old 07-29-2011, 08:09 PM
  #740
1LowLS's Avatar
I wanna say a .020 over bore makes it to a 2.3 liter.More displacement equals more air/fuel=more power.Im gonna over sleeve my block/blockguard and stroke it to a 4 liter 4 cylinder lol jk.My buddy has a big block chevy thats 865 cubic inches.Do the math and thats 14.1 liters lol.its a beast.
Old 08-10-2011, 08:00 AM
  #741
conerboner's Avatar
so my friend works at the dealer here in town and he can use the lift wednesday and saturday. I'm gonna get my car on a lift tonight after work and see what I can find but I have no idea where to even start lol.
Old 08-10-2011, 11:53 AM
  #742
kxrida2000's Avatar
holy fack..thats like a 5 inch bore lol
Old 08-11-2011, 10:18 PM
  #743
conerboner's Avatar
ugh i just wanna get my car running again. I think I'm gonna change the fuel filter again and see what happens. It ran good for a while when I changed it the first time so maybe it just got clogged again right away?
Old 08-11-2011, 10:25 PM
  #744
kxrida2000's Avatar
doubtful man..wat exactly is it doing again?
Old 08-12-2011, 09:13 AM
  #745
conerboner's Avatar
It will run good for a little bit and then it just shuts off. Vince said the logs look like the fuel supply just disappears but the car doesn't bog at all it shuts off like it would if you turned the key off.
Old 08-12-2011, 03:07 PM
  #746
Check your fuel rail too make sure theres nothing getting pass the filter.
Old 08-12-2011, 04:09 PM
  #747
1LowLS's Avatar
sounds like the pump is shutting off.Its possible the relay is getting hot and shutting itself off.Try swapping with another relay and see if that fixes the problem
Old 08-12-2011, 10:55 PM
  #748
conerboner's Avatar
alright i'll do that tomorrow. Also, I think i might put the stock manifold on the car. the 2.4 one I got had a different size hole for the map senser and i'm thinking maybe unmetered air is getting in there from how I had to drill it a little bigger to make the sensor fit. It probably isn't getting a good seal. but I will check the fuel rail and relay first.
Old 08-13-2011, 12:00 AM
  #749
1LowLS's Avatar
I had to do the same on mine b4 I was SC.06 LE5 map sensors were smaller.They changed in 07 to the big style like we have.I used a dremel on mine and shaved it then used some black silicone on the side of the seal to ensure there was no leak.Try that but if it were leaking through there,it would either run super lean,miss,or both.Not shut off.hmmm?!?!Try the relay swap.Sounds like either that or maybe the pump is actually getting too hot and shutting off.I dunno,I'm taking an educated guess here.
Old 08-13-2011, 01:01 AM
  #750
conerboner's Avatar
Would a rewire kit help if it is the pump getting too hot?
Quick Reply: wanna build my 2.2 up for more boost!
