wanna build my 2.2 up for more boost!
#732
more displacement.if you order pistons with stock sleeves,you dont get an overbore.you just need to hone the cylinders out to get the glaze out.if you sleeve your block and bore it out is when you buy over bored pistons
#734
Wanted your guys opinion...
Running an m62, stock internals... safe to push it to a 2.85? I had planned a 2.9" pulley as that's what others have beeen successful with. Not sure how much of a difference would even be seen.
#736
Oh well ...now I know what to buy
#740
I wanna say a .020 over bore makes it to a 2.3 liter.More displacement equals more air/fuel=more power.Im gonna over sleeve my block/blockguard and stroke it to a 4 liter 4 cylinder lol jk.My buddy has a big block chevy thats 865 cubic inches.Do the math and thats 14.1 liters lol.its a beast.
#742
#747
sounds like the pump is shutting off.Its possible the relay is getting hot and shutting itself off.Try swapping with another relay and see if that fixes the problem
#748
alright i'll do that tomorrow. Also, I think i might put the stock manifold on the car. the 2.4 one I got had a different size hole for the map senser and i'm thinking maybe unmetered air is getting in there from how I had to drill it a little bigger to make the sensor fit. It probably isn't getting a good seal. but I will check the fuel rail and relay first.
#749
