wanna build my 2.2 up for more boost!
Old 09-22-2011, 12:10 AM
  #801
CobaltLs505's Avatar
I sold mine for $125 plus shipping
Old 09-22-2011, 12:42 AM
  #802
Tundraboarder666's Avatar
I sold my K&N for $150 I think
Old 09-22-2011, 10:24 AM
  #803
IonNinja's Avatar
Originally Posted by 07cobaltguy
2.7-2.9 and the awesome 3.1 60' time. lol 1st 2nd and then i bog third since im spinning i shift short, i make up all the time after the 1/8th mile. my 1/8th time is like 10seconds lol. My slips are in the 2011 drag times thread in the drag racing section.
what turbo are you running? that thing moves!
Old 09-22-2011, 11:42 PM
  #804
06_ion2's Avatar
Try running some bkr7e's i havent missfired on mine even though its the "wrong plug".
Old 09-23-2011, 12:40 AM
  #805
Going to put zzp valve springs in... its not the plugs I've been through 40 of em. Stock ones are too weak.
Old 09-23-2011, 04:14 PM
  #806
07cobaltguy's Avatar
57 trim ebay turbo
Old 09-23-2011, 04:39 PM
  #807
Spanky's Monkey's Avatar
you guys are making me want to put the turbo back on. i need the money bad though so it's gonna stay off.
Old 09-23-2011, 06:37 PM
  #808
1LowLS's Avatar
Word.Hopefully that clears this issue so we can see what this E85 beast will do
Old 09-24-2011, 04:18 AM
  #809
Hey guys I have a question. I know my car is running like **** cause the new tune, I recently fixed a exhaust leak. I took a vid from my phone so the quality is ****. My car is only on 4psi so my question is it safe to drive the car if my Air flow ratio is this bad?
Cobalt LS/TC Running Like **** - YouTube
Old 09-24-2011, 04:26 AM
  #810
Wow it's kinda everywhere... WOT actually looked the best lol.
You will be fine driving it just becareful when the trims get so lean you cant read them.
Old 09-24-2011, 04:27 AM
  #811
1LowLS's Avatar
look while cruising its where it supposed to be but when you start letting off the gas its going super rich.Just listen for knock or sputter.If its knocking(detonating) I wouldn't drive it but I couldn't tell from the vid.running that rich usually wont hurt anything other than fouling out the plugs but just listen to it and you should be able to tell.
Old 09-24-2011, 04:36 AM
  #812
Get Vince to fix that **** ASAP though!
Old 09-24-2011, 04:43 AM
  #813
1LowLS's Avatar
Word^^^^
Old 09-24-2011, 07:28 AM
  #814
conerboner's Avatar
if i let off going down a hill and leave it in gear it goes over to the lean side and the numbers don't show... but if i put it in neutral it stays at 14.7 I have never heard any knock but i don't have an interceptor to confirm this...
Old 09-24-2011, 11:08 AM
  #815
paintballerr78's Avatar
If your leaving it in gear and going down hill your most likely going into fuel cut off thats why it goes so lean...As taylor tells me hahah and for taking it out of gear id just imagine cause it thinks its driving idk
Old 09-24-2011, 11:21 AM
  #816
1LowLS's Avatar
its the difference of the engine rpm being forced higher when in gear as opposed to when its in neutral its commanding 14.7:1 afr.When it goes super lean for a momnet when letting off the gas is usually normal and it'll correct itself.
Old 09-24-2011, 11:57 AM
  #817
I already sent a data log to Vince but I think he just had his baby, so it'll be while till he gets back at me, I'm considering switching to HPT
Old 09-24-2011, 01:56 PM
  #818
1LowLS's Avatar
I would and am^^ .My TF tune has never been spot on.
Old 09-24-2011, 02:36 PM
  #819
R u gonna tune it yourself or get someone to tune it for u?
Old 09-24-2011, 03:08 PM
  #820
1LowLS's Avatar
Im gonna have a local tuner do it.He Tuned his own twincharged LSJ and is in process of tuning Tundra's E85 turbo 2.2.My cruising and WOT AFR's are great,it;s just Vince cant get me a smooth idle.Tundra had the same problem and as soon as he went HPT,smooth idle.Im just tired of the back and forth games and having to wait so long to get my car to idle right.Other than the Idle problem the TF tune was great.
Old 09-24-2011, 03:16 PM
  #821
That^
Old 09-24-2011, 03:25 PM
  #822
That's how mine is before this last tune update my car was running great except the idle kinda rough but if I get tuned I'm guessing it'll be by BYT. I bought the tuning school so I could start learning how to tune my own car and also L61,LAP, and LE5
Old 09-24-2011, 03:30 PM
  #823
1LowLS's Avatar
That's cool.I just don't have the patience anymore.lol
Old 09-24-2011, 04:46 PM
  #824
and the hpt vs. tft thing is why I could care less about having any more issues with tuning my 06. just not worth it to have the back and forth and feel like i'm getting no where that i want to be. i'll save the turbo fun for a different turbo'd car.
Old 09-26-2011, 08:11 AM
  #825
Ive always had great luck with vince usually 2 maybe 3 logs at the most. Car has always ran great.
Quick Reply: wanna build my 2.2 up for more boost!
