wanna build my 2.2 up for more boost!
#878
Personally my werks intercooler wouldn't fit behind my stock bumper. Fits perfect under ss bumper, about 1 inch above bottom lip. I know you can fit one of the smaller ones under base model bumper.
#881
SOOOOOOO..... My motor didnt like 300whp on the stock bottom end. Made a nice window in the block, Luckly the rod missed the intake manifold so that didnt get trashed.
On a good note, I got to try out my TBSS, pulled the cobalt like a champ. Im at least pleased with that.
#885
with the corn it was ok for a good 4/5 months and a few track passes. Yeah if the crank is still good i will build it, i found a bare short block for $150 then just rods,pistons,studs and a gasket and im set. I have enough spare engine parts to build almost two engines lol.
#886
On a side note, I did what i set out to do, see how far you can push the block with e85 and pulled trap speeds good for low 12's so id say im impressed with the engine.
#891
haha nice. i had to pull my built motor. pulled it and tranny together (after pulling it over 10 times its easier that way) it took me prop 1.5-2hrs to disconnect everything and pull the motor/trans out just last month. stock motor for winter, built motor going back in with ITB, maybe bigger cams and WI this spring... looking for near 300whp
sorry to hear for ur loss, but that only a few hundred $ fix lol get her back on the road soon
#895
got my turbo off today hopefully can get the manifold off tomorrow so i can send it in and get my new one! I'm also thinking about getting my turbo powdercoated yellow but not sure if it will hold up to the heat? I wish they had jet hot coating in yellow.
#898
Yeah I know man... Mine just has a consistent pull that keeps you in your seat. i can't imagine how yours feels having to shift, give you frikken whiplash haha
