wanna build my 2.2 up for more boost!
Old 11-01-2011, 09:07 PM
  #876
1LowLS's Avatar
yeah which wouldnt be too hard
Old 11-02-2011, 09:49 AM
  #877
06_cobalt's Avatar
Exactly. Now will an intercooler fit behind the factory bumper easily?
Old 11-02-2011, 11:20 AM
  #878
Brags's Avatar
Personally my werks intercooler wouldn't fit behind my stock bumper. Fits perfect under ss bumper, about 1 inch above bottom lip. I know you can fit one of the smaller ones under base model bumper.
Old 11-02-2011, 01:36 PM
  #879
06_cobalt's Avatar
Ok. I assumed a small one would. Because if I turbo I want to keep the stock bumper to go for the sleeper look.
Old 11-02-2011, 03:43 PM
  #880
1LowLS's Avatar
A smaller IC would fit behind there.I had a ebay IC that fit behind my stock LS bumper.
Old 11-13-2011, 09:35 AM
  #881
07cobaltguy's Avatar
SOOOOOOO..... My motor didnt like 300whp on the stock bottom end. Made a nice window in the block, Luckly the rod missed the intake manifold so that didnt get trashed.
On a good note, I got to try out my TBSS, pulled the cobalt like a champ. Im at least pleased with that.
Old 11-13-2011, 10:19 AM
  #882
Brags's Avatar
Sucks to hear. You going to rebuild? Gen II block rods and pistons and youll be good.
Old 11-13-2011, 12:52 PM
  #883
Tundraboarder666's Avatar
yeah... I would assume he's rebuilding it... theres no way you would think you would be okay on a stock bottom end making that much whp
Old 11-13-2011, 01:57 PM
  #884
1LowLS's Avatar
I'm gonna be on E85 and I think being on the M62 with E will be too much for the bottom end.We'll find out lol
Old 11-13-2011, 06:18 PM
  #885
with the corn it was ok for a good 4/5 months and a few track passes. Yeah if the crank is still good i will build it, i found a bare short block for $150 then just rods,pistons,studs and a gasket and im set. I have enough spare engine parts to build almost two engines lol.
Old 11-13-2011, 06:20 PM
  #886
On a side note, I did what i set out to do, see how far you can push the block with e85 and pulled trap speeds good for low 12's so id say im impressed with the engine.
Old 11-14-2011, 04:14 PM
  #887
Brags's Avatar
So what was is that blew, rod, bearings, sleeve?
Old 11-14-2011, 04:37 PM
  #888
elecblue06's Avatar
Old 11-14-2011, 06:15 PM
  #889
i have to get the motor out this weekend. Only took me 45mins to get it prepped to pull. i am getting pretty good at it lol.
Old 11-15-2011, 06:17 PM
  #890
There it is.
Old 11-29-2011, 09:16 AM
  #891
o3nisoaso3's Avatar
haha nice. i had to pull my built motor. pulled it and tranny together (after pulling it over 10 times its easier that way) it took me prop 1.5-2hrs to disconnect everything and pull the motor/trans out just last month. stock motor for winter, built motor going back in with ITB, maybe bigger cams and WI this spring... looking for near 300whp
sorry to hear for ur loss, but that only a few hundred $ fix lol get her back on the road soon
Old 01-21-2012, 12:49 AM
  #892
conerboner's Avatar
so finally got around to trying to get my turbo mani off and it's cracked on all the welds!!! ugh guess i'll have to get the revised turbo manifold from zzp...
Old 01-21-2012, 06:53 AM
  #893
my vulcan cracked everywhere too. It was warpped i got it welded and then when i bolted it down it cracked again.
Old 01-21-2012, 10:53 AM
  #894
Trans shifts super hard now with IPT's upgrades
Old 01-21-2012, 12:10 PM
  #895
Brags's Avatar
I wish you were closer, I'd like to feel dif between turbo auto and turbo manual. Mine should finally be home next week.
Old 02-18-2012, 08:31 PM
  #896
conerboner's Avatar
got my turbo off today hopefully can get the manifold off tomorrow so i can send it in and get my new one! I'm also thinking about getting my turbo powdercoated yellow but not sure if it will hold up to the heat? I wish they had jet hot coating in yellow.
Old 02-18-2012, 10:41 PM
  #897
CobaltLs505's Avatar
What was wrong With your turbo?
Old 02-19-2012, 12:03 AM
  #898
Yeah I know man... Mine just has a consistent pull that keeps you in your seat. i can't imagine how yours feels having to shift, give you frikken whiplash haha
Old 02-19-2012, 12:04 AM
  #899
conerboner's Avatar
Took it off to get better access to the bolts on the manifold
Old 02-24-2012, 07:21 PM
  #900
conerboner's Avatar
anyone have any tricks for getting off a rounded off exhaust manifold nut? i tried to just take the whole stud off with an e7 torx bit but the tip broke off with very little effort. epic fail
Quick Reply: wanna build my 2.2 up for more boost!
