wanna build my 2.2 up for more boost!
Old 02-16-2011, 09:44 PM
  #76
conerboner's Avatar
Idk total price haha try not to think about it all. I went with stock bore and 8.9:1 compression. The only valve train work i'm doing is the valve springs.
Old 02-16-2011, 10:23 PM
  #77
redcobalt07's Avatar
Man I need to get on this thread too. I love all the 2.2 guys building our motors. Me and glow sc, pyscho and coner tc. This is great.
Old 02-16-2011, 10:25 PM
  #78
Glowbalt's Avatar
hey jared, check your thread..
Old 02-16-2011, 10:34 PM
  #79
PsychoCam's Avatar
what kind of valve springs you end up getting.
I am ready to build so bad. kxrider lives close to me so he will be helping lol
Old 02-16-2011, 10:35 PM
  #80
Can he help me out too?
Old 02-16-2011, 10:39 PM
  #81
conerboner's Avatar
zzp 78# springs. kxrida helped me out a lot with endless texts haha. I just need to get a harness for my 80s, walbro 255 and return style fuel system but that can wait till after the break in
Old 02-16-2011, 10:41 PM
  #82
Good lord, I don't think I'm thank intense lol. But I will be doing valves, valve springs, and that stuff
Old 02-16-2011, 10:42 PM
  #83
Glowbalt's Avatar
wootsauce! Glad you guys plan on doing this yourselves..Me? Eh not so much, got noone around here to help out so going to a shop is a must :/
Old 02-16-2011, 10:43 PM
  #84
PsychoCam's Avatar
is the walbro 255 a direct replacement?
ya i am ready to build more boost. this 10-11 psi is way too boring
If I am building I am building all at once. go big or go home haha
I will ask him I know he said I can use his garage bc of the lift. so I assume I will be buying lots of beer/food lol
Old 02-16-2011, 10:48 PM
  #85
would you go there vs foximus? And yeah I'm gonna have my motor just destroyed so I can make it better by summer.
  #86
stenguyen1's Avatar
I'm guessing no one really seen my build thread. The walbro is a universal pump but the zzp and ottp fuel pump rewire is suppose to help when your boosting more than 15psi.
Old 02-16-2011, 10:51 PM
  #87
PsychoCam's Avatar
so u can run stock pump and just use the zzp rewire to help with boost?
ya bc kxrida has a lift and he has already built his 2.2. I am tired of cralling on the floor haha. lift=heaven
Old 02-16-2011, 10:52 PM
  #88
Hmm I might have to contact him then for this. When do you think you are gonna start your build? I should have all my parts by mid april. And then do the build around may.
Old 02-18-2011, 11:10 AM
  #89
conerboner's Avatar
So the walbro isn't necessary? just the rewire would be enough? and should i go with the ottp return style fuel system or zzp's boost reference pressure system? I already have 80s and I have access to e85 up here in the midwest!
Old 02-18-2011, 11:49 AM
  #90
PsychoCam's Avatar
80's may be a little too much but i am not totally sure. they may try and dump too much fuel
Old 02-18-2011, 12:04 PM
  #91
Brags's Avatar
Keep up good work guys, dropped my car off at Performance Autowerks on tues. Should have some pics next week. Check my sig for whats going in
Old 02-18-2011, 12:13 PM
  #92
PsychoCam's Avatar
how are u running lnf control arms? did u have to get all new knuckles etc
Old 02-18-2011, 05:26 PM
  #93
Brags's Avatar
Nope, you just need to open up knuckle like 1cm then close up after putting in
Old 02-18-2011, 05:29 PM
  #94
PsychoCam's Avatar
i may have to look into this. I am so sick of my poly cab bushings
they suck so bad
Old 02-18-2011, 10:46 PM
  #95
joshc.'s Avatar
If he's going to run e85 he'll need them. You could always run smaller but thats pointless since most injector manufacturers say not to run an injector over 80 to 85% duty cycle.
I would run a return style fuel system and a larger a feed line to the rail if I wa swapping to e.
I would look into the part numbers of the Cobalt fuel pump and see if there is a difference between the pumps, since it been proven that the pumps flow significantly wll from the factory.
Old 02-19-2011, 12:03 PM
  #96
Brags's Avatar
The difference between Powell bushings w lnf arms is amazing. I went through 3 sets of stock ones before switching over. Lsj arms are just as good if you do it. Derilin bushings require regular maintenance fyi
Old 02-19-2011, 08:04 PM
  #97
conerboner's Avatar
OTTP said I would have to send my fuel rail in for them to make a return style fuel system work for the 2.2. Would zzp's boost reference fuel pressure system be adequate for e-85? And should I get a better fuel pump or just the rewire kit and call it a day?
Old 02-20-2011, 08:44 PM
  #98
conerboner's Avatar
bump for help on the fuel questions.
Old 02-24-2011, 09:22 AM
  #99
conerboner's Avatar
Well I plan on dropping the motor and tranny today. I'll try to get some pics but all i have is my phone. I hope to get it out of the car and take the valve cover and head off and start taking the pistons and rods out. Still gotta get the stupid circlips in the pistons to hold the piston pin on the new ones.
Old 02-24-2011, 09:47 AM
  #100
NJHK's Avatar
Originally Posted by kxrida2000
either or for the bearings..and sleeve it if ur gonna go high boost..ive seen way to many crack a sleeve and are left with nothing
Sleeves are purely optional for someone who is not running a ton of power. I've been around the L61s since 2003, never seen anyone have sleeve issues.
Quick Reply: wanna build my 2.2 up for more boost!
