wanna build my 2.2 up for more boost!
#84
is the walbro 255 a direct replacement?
ya i am ready to build more boost. this 10-11 psi is way too boring
If I am building I am building all at once. go big or go home haha
I will ask him I know he said I can use his garage bc of the lift. so I assume I will be buying lots of beer/food lol
#85
#87
ya bc kxrida has a lift and he has already built his 2.2. I am tired of cralling on the floor haha. lift=heaven
#95
I would run a return style fuel system and a larger a feed line to the rail if I wa swapping to e.
I would look into the part numbers of the Cobalt fuel pump and see if there is a difference between the pumps, since it been proven that the pumps flow significantly wll from the factory.
#96
The difference between Powell bushings w lnf arms is amazing. I went through 3 sets of stock ones before switching over. Lsj arms are just as good if you do it. Derilin bushings require regular maintenance fyi
#97
If he's going to run e85 he'll need them. You could always run smaller but thats pointless since most injector manufacturers say not to run an injector over 80 to 85% duty cycle.
#99
Well I plan on dropping the motor and tranny today. I'll try to get some pics but all i have is my phone. I hope to get it out of the car and take the valve cover and head off and start taking the pistons and rods out. Still gotta get the stupid circlips in the pistons to hold the piston pin on the new ones.
#100
Sleeves are purely optional for someone who is not running a ton of power. I've been around the L61s since 2003, never seen anyone have sleeve issues.
