wanna build my 2.2 up for more boost!
Old 04-10-2012, 04:17 PM
  #976
conerboner's Avatar
do any 2.2's have the saab intake mani for a boosted setup? I'm considering getting one if I don't have to change my intercooler piping around. if not i'll get a sheet metal one and an air-air intercooler but i dont want to spend a fortune on a new set up lol
Old 04-10-2012, 04:40 PM
  #977
PsychoCam's Avatar
I heard brags had a lot of tuning issues with his or something. I would ask him. I don't think it works right with the 2.2
Old 04-10-2012, 04:45 PM
  #978
rcarr0327's Avatar
yea i would also like to know this, let me know if u find out info
Old 04-10-2012, 06:09 PM
  #979
Brags's Avatar
My experience with it was bad, couldn't get the pcv system to work right, all gaskets were matched. Now back on 2.4 running beastly.
Old 04-10-2012, 06:37 PM
  #980
kxrida2000's Avatar
I used a liquid air setup with a ttr manifold. Just gotta Fab a pipe which I believe I still have
Old 04-10-2012, 11:00 PM
  #981
conerboner's Avatar
New axles will be here Friday
Old 04-11-2012, 01:11 PM
  #982
sfwg's Avatar
Stg 2's from Drive shaft shop?^
Old 04-11-2012, 02:35 PM
  #983
conerboner's Avatar
no stage 1 from zzp. I'm not spending 800 bucks on axles that can only take 400 hp
Old 04-16-2012, 09:35 PM
  #984
06_ion2's Avatar
I paid like $280 for DSS axles and havent had a problem at all with them and my car hooks very well.
Old 04-17-2012, 09:28 PM
  #985
sfwg's Avatar
you do realize thats where zzp gets them from right?
Old 04-18-2012, 07:19 AM
  #986
conerboner's Avatar
Are you sure? i was under the impression they were the napa ones.
Old 04-18-2012, 12:29 PM
  #987
sfwg's Avatar
hmm...
Old 04-26-2012, 04:47 PM
  #988
conerboner's Avatar
forgot to put the gopro on 1080 but in this vid you can kind of see me shoot a flame at ~10 seconds lol
Old 04-26-2012, 04:51 PM
  #989
Tundraboarder666's Avatar
nice! haha
Old 04-30-2012, 05:16 PM
  #990
1LowLS's Avatar
that's a good size flame for you to be able to see the flash from that angle haha.spittin hot FYAAAAHHHH!!!!
Old 04-30-2012, 07:09 PM
  #991
BankerBalt's Avatar
so ima post this here because i know someone will have answers for me... copied from MN chat
so i think i'm pretty close to having all the parts i need to rebuild this dumb car... please chime in if i need anything more than this...
wiseco pistons w/ stock characteristics
eagle rods
all girdle bolts
arp head studs
arp flywheel bolts
new timing set
dual pass endplate
2.8" pulley
oversized tensioner pulley
rear main seal
front main seal
intake manifold gasket
all exhaust gaskets
new downpipe
valve cover gasket
timing cover gasket
exedy lightweight flywheel
exedy stage 2 clutch
cometic MLS head gasket
still waiting to buy rod/main bearings and injectors. will need a new fuel pump, walbro 250, right? does the 42lb injector harness hook up to 80's by chance?
Old 04-30-2012, 11:57 PM
  #992
06_ion2's Avatar
your missing the zzp turbo kit.
Old 05-01-2012, 12:02 AM
  #993
BankerBalt's Avatar
**** i knew i was forgetting something
Old 05-09-2012, 11:52 AM
  #994
conerboner's Avatar
going to the track this weekend hopefully i don't break anything lol
Old 07-08-2012, 11:07 AM
  #995
conerboner's Avatar
did you get a chance to look and see if you still have it? or a picture of it so I can see what I need to look for or make
Old 07-09-2012, 01:26 AM
  #996
06_ion2's Avatar
blew out 3rd gear, FML.
Old 07-09-2012, 01:31 AM
  #997
AzraelRaezier's Avatar
are you an auto?
Old 07-09-2012, 01:53 AM
  #998
Negative, he is not...
Story?
Old 07-09-2012, 01:59 AM
  #999
06_ion2's Avatar
Story?
Well i raped on it in 2nd and hit 3rd while half boosted so it spooled up almost instantly. My car hooks very well so it didnt spin much at all. The end of the pull in 3rd i let off and it fell out of gear. So it only stays in 3rd if i push it hard forward so i assume the shift fork is bent? All other gears are ok, but the syncros in 2nd are also pretty much gone. Oh well it lasted almost 20k miles on 20+psi. Being beaten on a lot.
Old 07-09-2012, 02:05 AM
  #1000
damn... aftermarket clutch?
Quick Reply: wanna build my 2.2 up for more boost!
