wanna build my 2.2 up for more boost!
Old 03-06-2011, 03:49 PM
  #126
conerboner's Avatar
yes the 2.4 is also plastic lol. I want to get a sheet metal IM but i'd have to do new intercooler piping and i'm too lazy lol
Old 03-06-2011, 03:50 PM
  #127
conerboner's Avatar
Originally Posted by BlackCobalt707
you do realize the 2.4 IM is plastic as well right?
anyways, im just coming it to check up on the progress of the build. looks like its coming along, keep the good work
Thanks, I'm doing all the work myelf and i've never done any of this before so I'm taking my time to do it right the first time!
Old 03-06-2011, 04:03 PM
  #128
Spanky's Monkey's Avatar
timing is easy just takes a while cranking it by hand until the marks all line up again. seriously i was at it for about 15 mins slowing turning the crank over.
Old 03-06-2011, 04:08 PM
  #129
conerboner's Avatar
Sweet. How much should I expect to pay to get the new valve springs put in, crank balanced and flywheel resurfaced?
Old 03-06-2011, 04:12 PM
  #130
BlackCobalt707's Avatar
damn, good ****. doin it right the first time is the way to go, one wrong thing could end bad lol
i know exactly wat you mean lol. that **** sucked
Old 03-06-2011, 04:16 PM
  #131
i wish i knew prices on the valve train that stuff was done by my cousin the crank balance did run me $200 because my cousin srouces that job out and trusts the guy he uses.
Old 03-06-2011, 04:41 PM
  #132
Brags's Avatar
Originally Posted by Glowbalt
should add a 2.4 IM..I wouldn't trust those plastic POS's
Use the lk9 manifold from saab 9-3, bolts up perfect with motor and 2.4 tb. You just need to open things up a little. Its cast metal and can find for under $100 used
Old 03-06-2011, 04:46 PM
  #133
conerboner's Avatar
2000 Saab 9-3: AIR INTAKE manifold - eBay (item 220701535453 end time Mar-24-11 15:02:23 PDT)
Would one like that work?
Old 03-06-2011, 04:48 PM
  #134
Brags's Avatar
Nope to old, I believe its 2003-2007
Old 03-06-2011, 05:25 PM
  #135
conerboner's Avatar
Saab Parts Center - Call (800) 518-7694 for Genuine Saab Porsche Parts and Accessories
So I might as well just buy a new one but do I get the one with high output or without high output? and does the 2.2 throttle body bolt up or will the hole on the manifold need to be opened up?
Old 03-06-2011, 05:40 PM
  #136
Brags's Avatar
Im not sure about 2.2 tb never tried it
Old 03-06-2011, 06:03 PM
  #137
kxrida2000's Avatar
2.2 and 2.4 tbs have the same bolt pattern so it should be the same if the 2.4 bolted up for bragdon
Old 03-06-2011, 07:02 PM
  #138
joshc.'s Avatar
Pretty sure there was no difference between the LK9 HO and LO intake manifolds or exhuast manifolds. The main difference was the turbocharger and tune. everything else was the same.
Old 03-06-2011, 07:03 PM
  #139
Brags's Avatar
this is correct I believe
Old 03-06-2011, 08:49 PM
  #140
conerboner's Avatar
ok cuz the ho one is cheaper. or should i get the one from zzp that can have the map sensor and an extra bung for the boost gauge?
Old 03-06-2011, 09:07 PM
  #141
redcobalt07's Avatar
This thread is great for information.
Old 03-06-2011, 09:10 PM
  #142
kxrida2000's Avatar
u can just stick with ur mani if its a 2.4...you will not pop it most likely. I ran 25 psi from my 256et through mine and it held just fine and i doubt u will be running 25 psi so i wouldnt buy the lk9 mani unless u have the money to spend
Old 03-07-2011, 07:16 AM
  #143
conerboner's Avatar
I still have the stock 2.2 IM and TB right now.
Old 03-07-2011, 10:34 AM
  #144
Brags's Avatar
You def want to switch to at least a 2.4, I might have one for cheap in a week
Old 03-07-2011, 12:12 PM
  #145
conerboner's Avatar
You gonna be selling just the IM or the IM and TB? Should I upgrade both while i'm at it?
Old 03-07-2011, 12:25 PM
  #146
HyperMuffin's Avatar
You could always buy a lsj intake mani and the zzp block off plate. Then might as well run a LSJ TB.
http://www.zzperformance.com/cobalt_...ts1.php?id=971
Old 03-07-2011, 02:00 PM
  #147
conerboner's Avatar
not trying to spend more than i have to lol. I just dropped my head and flywheel off to get the valvesprings put in and the flywheel resurfaced but I have to go to a different shop to get my crank balanced.
Old 03-07-2011, 02:07 PM
  #148
exiged's Avatar
saved
Old 03-07-2011, 03:57 PM
  #149
kxrida2000's Avatar
my 2.4 manifold is for sale..its tapped with 3 barbed fittings for vacuum lines for the bov..wg..and boost gauge so u dont hve to tee off all the lines
Old 03-07-2011, 04:04 PM
  #150
conerboner's Avatar
how much?! I'll take it! text me i'm at work
Quick Reply: wanna build my 2.2 up for more boost!
