wat could cause low vaccum
Old 08-04-2010, 12:16 PM
kxrida2000's Avatar
I have a Turbo swapped 2.2 and my vac is at like 17 at idle Wat all could cause this
Old 08-04-2010, 12:19 PM
EcoTecDriver's Avatar
A leak, check your hoses and such, or perhaps your throttle is open when it shouldnt be, thats what im dealing with on my m62 powered l61
ItalianJoe1's Avatar
That's not that far off.
Normally, a drop in vacuum is a piston sealing issue or a IAC/TB problem. After working with a ZZP 2.4L turbo kit, I found the car wasn't too crazy about the blow-through MAF and it gave me weird idle vac until the car settled down sometimes, TB just kept moving around.
If you're worried, do a compression test. Otherwise, don't worry about it
Old 08-04-2010, 12:54 PM
kxrida2000's Avatar
Compression is perfect but at idle it stalls and would be impossible to drive...also mu bov bleeds off at like 2k rpm
Old 08-04-2010, 12:57 PM
Fail Less.
Bika's Avatar
either a leak in a vac hose, or you are leaking compression off the rings / valve seals.
But 17 is not bad for vacuum.
Old 08-09-2010, 11:56 PM
Domkk333's Avatar
could it have anything to do with low compression style pistons?
Old 08-09-2010, 11:59 PM
You dont have a leak @ 17, is what they are saying^^^^
Old 08-10-2010, 07:53 AM
kxrida2000's Avatar
My bov will not open normally could this be due to a faulty bov? If I hold a vac booster to it and pump it to like 20 the bov will open? Any ideas
Old 08-10-2010, 11:32 AM
Im not familiar with turbo setups sorry, free bump
Old 08-10-2010, 04:57 PM
Jn2
Jn2's Avatar
dont know if it helps bc im sc'd and ur tc's...but my idle is -20@idle, and -17/16 @idle with the a/c on...turn the ac off and it will go to -20...during decelarration while in gear i will be -24...just a boost leak down test to see if your leaking anywhere, be sure to put the engine in TDC so all valves are closed...
Old 08-11-2010, 01:01 AM
06_ion2's Avatar
I see -14 but I think my motor's rings are fucked.
Old 08-11-2010, 09:22 AM
kxrida2000's Avatar
what is the most effective way to do a leak down lest on my whole system? engine a tdc and how do i actually pressurize it?
Old 08-11-2010, 09:31 AM
I'm too JDM for you
BLAZIN07SS's Avatar
what bov do you have?
Old 08-11-2010, 09:51 AM
kxrida2000's Avatar
The one that came with the zzp Turbo kit like a knockoff tial
Old 08-11-2010, 10:01 AM
I'm too JDM for you
BLAZIN07SS's Avatar
might have the wrong spring in it
Old 08-11-2010, 10:12 AM
kxrida2000's Avatar
My buddy has a spare hks should I try to use that for now as temporary or should I try a different spring
Old 08-11-2010, 10:19 AM
06_ion2's Avatar
Mine works just fine on my car.
Old 08-11-2010, 10:21 AM
Stamina's Avatar
Man, when I first read the title, I thought you were saying WOT causes low vacuum. I was like, well.... yeah...
Old 08-11-2010, 10:25 AM
I'm too JDM for you
BLAZIN07SS's Avatar
could try a different spring first. you can use tial parts in that zzp knock off. you can use a -9psi spring if it idles at 17inHg of vacuum
Old 08-11-2010, 10:40 AM
kxrida2000's Avatar
OK man thanks a lot also any ideas on why my car is so rich at idle...would not have a return fuel setup cause this issue because after 2000 rpm the car runs flawless also when I Rev the car when it comes back down it dies
Haha I'm not that dumb but ya this car Is driving me insane
I'm too JDM for you
BLAZIN07SS's Avatar
so you have a return style fuel system? what is your base pressure set at?
Old 08-11-2010, 10:49 AM
kxrida2000's Avatar
Well here is the thing...I have zzp boost reference fuel system an I have it hooked up but I looked at my regulator in my tank and I cant take the ball an spring out like zzp say cause my regulator is a sealed unit...so its not really doing anything is IT? and could this be causing the issue with rough idle and way too much fuel at idle
originaladrian's Avatar
pretty sure he has a returnless setup
Old 08-11-2010, 10:57 AM
06_ion2's Avatar
Email Ryan?
Old 08-11-2010, 10:58 AM
kxrida2000's Avatar
Originally Posted by 06_ion2
Email Ryan?
He wont answer no one at zzp will
Quick Reply: wat could cause low vaccum
