wat could cause low vaccum
I'm too JDM for you
Well here is the thing...I have zzp boost reference fuel system an I have it hooked up but I looked at my regulator in my tank and I cant take the ball an spring out like zzp say cause my regulator is a sealed unit...so its not really doing anything is IT? and could this be causing the issue with rough idle and way too much fuel at idle
u need to take off the charge pipe from the turbo and hook up a air compressor to it, set the compressor to a psi slightly higher than what you normally run, make sure engine is TDC so the valves are closed and air doesnt leak into the engine and out the exhaust...if it hold the pressure than your good, if it doesnt, listen for the leaking air...
importkiller
09-30-2015 07:18 PM
