weird hiss after installing 2.5 downpipe
Old 09-20-2011, 10:33 PM
Cobalt08LS's Avatar
this was the vid i took on thurs. ill try n get another vid or 2 taken to see if i can get the noise im having anoyance with
Old 09-20-2011, 10:36 PM
punksk8ter62's Avatar
a4351a91.mp4 video by punksk8ter62 - Photobucket
Vid is from inside the car. It's only under load mine does it. Haven't had n e problems with it tho. Just annoying as hell.
Old 09-20-2011, 10:37 PM
chris88z24's Avatar
It's probably just air flowing through the flexpipe. Drive it for a few thousand miles and check the gasket, it'll be black if there are any leaks. The steel is also thinner than stock so youre going to hear more noise. Don't mod the car if you want it to be quiet lol
Old 09-20-2011, 10:38 PM
Cobalt08LS's Avatar
@ 11 is kindaa how mind sounds. its right after 2k where it totaly gets loud. ill try to take some vids
Old 09-20-2011, 10:39 PM
Cobalt08LS's Avatar
k im not talking about not liking that the car is louder. i love how it sounds w the dp just this noise im getting is anoying. meet up with me and i will show you and get your view on it if you want to hear it.
Old 09-20-2011, 10:43 PM
Cool. I'll check back tomorrow and see if you've posted n e. I'm sure it's just the airflow.
Old 09-20-2011, 10:44 PM
chris88z24's Avatar
If its hissing when the motor is under load and there are no leaks then its just the air whooshing through the flex section.
Old 09-20-2011, 10:45 PM
Cobalt08LS's Avatar
maby its that. do u want to check it out chris?
Old 09-20-2011, 10:48 PM
chris88z24's Avatar
no. lol
Old 09-20-2011, 10:49 PM
Cobalt08LS's Avatar
deff is comin from the filter side
Old 09-20-2011, 10:58 PM
  #36
Cobalt08LS's Avatar
there is also a hole im my sai tube from rubbing against the belt. would that hace any key in my problem?
there is also a hole im my sai tube from rubbing against a belt. would that have any key in my problem?
Old 09-20-2011, 10:59 PM
  #37
chris88z24's Avatar
maybe but the zzp downpipes are definitely noisier than stock. and by noisy i mean that hissing sound you described
Old 09-20-2011, 11:08 PM
  #38
Cobalt08LS's Avatar
yeah i took some vids ill have to see if you can hear the noise when i upload them
can kinda hear it starting at the 5 sec mark
and a little bit here
Old 09-21-2011, 09:25 AM
  #39
Cobalt08LS's Avatar
bumppp i took off the filter checked it loosened the heat shield and moved it around and it still does the noise. how do i get rid of it. would like if more 2.2 users with this downpipe chime in
Old 09-21-2011, 09:27 AM
  #40
zerosk8ter83's Avatar
exhaust leak?
Old 09-21-2011, 10:02 AM
  #41
Cobalt08LS's Avatar
went to the shop yesterday and they checked both downpipe gaskets and showed no leak. when i rev in neutral when driving you can hear it come right out the muffler. im not sure if my downpipe is defective or if this is the normal noise the downpipe does. but to me it sounds like **** and is leaning me towards wanting to take it off. maby an lsj downpipe would be a tad better? im going to contact zzp
Old 09-21-2011, 01:59 PM
  #42
Cobalt08LS's Avatar
zzp said this. It's quite normal. You'd have to change other parts of the exhaust to make it change. It's from less back pressure but it just doesnt sound right to me because when im cruising in higher rpms it sounds like complete ****...
when i rev i can hear the intake suck in air. than i hear the noise im talking about
heres a other video. you can kinda hear it when the rpms are at the highest.
it sounds like its something near my intake. but my intake makes the noise it did when i first installed it combined with this new noise thats anoying when im driving. i cant get a clear video when driving no matter how hard i try. if i can get one as clear as it is that i hear when im driving than you guys would be able to hear it alottt better
heres a pic of the flange. what is that black stuff to the righ by/on the gasket. .?
Old 09-21-2011, 04:48 PM
  #43
Cobalt08LS's Avatar
i have an audio recording i took with my iphone that you can kinda hear it making the noise when driving. if someone can tell me how i can put it on here ill do so
Old 09-21-2011, 05:02 PM
  #44
dmeine13's Avatar
tbh.... it sounds normal to me.
Old 09-21-2011, 05:39 PM
  #45
Cobalt08LS's Avatar
thats probally because the sound i get when cruising isnt able to be heard thru video. it can be heard in the recordings i did on my phone but i dont know how to get them on here
Old 09-21-2011, 07:38 PM
  #46
Cobalt08LS's Avatar
bumpp
Old 09-21-2011, 07:58 PM
  #47
im sure zzp is right. but that might be a leak on your gasket. you could buy a new gasket and retorque the bolts. i also used rtv orange and a gasket right there and let it set overnight to get rid of that noise. i used to think it was a broke flex pipe. now im just learning to get used to it. lol.
Old 09-21-2011, 08:06 PM
  #48
Cobalt08LS's Avatar
yeah well i have no access to a lift on my own time or any of that stuff. also i went to the exhaust shop who did the install they lifted the car revved it in the air and looked at everything and they said there was no leak whatsoever. theres a hole in my SAI tube would that contribute to anything?
Old 09-21-2011, 09:24 PM
  #49
LS2SS's Avatar
Just switch to a regular CAI where the cone is down by the wheel well/bumper area bc thats what i have and i just here the exhaust nothing from the intake
Old 09-21-2011, 10:01 PM
  #50
Cobalt08LS's Avatar
well i hear the intake fine. its just this noise i get when driving that is pissing me the hell off.
does anyone thing the hole in my SAI tube is to cause for this noise since their would be air getting in the sai tube than into my header than down my exhaust system
Quick Reply: weird hiss after installing 2.5 downpipe
