Weird vibration
Weird vibration
ok guys just started noticing this...when I am just driving around like normal i notice a very noticealbe vibration in the gas pedal when going anywhere from 40-60 mph...its really weird. the vibration is so noticeable that it almost makes a humming noise. Anyone have any ideas what it could be? BTW i'm automatic
first..recheck your lugnuts to make sure they are torqued...
second your wheels are probably going to need re balanced..an unbalanced wheel will cause a vibration at only certain speeds..usually higher ones
umm....its about the same vibration as in the gas pedal.
its a steady humming like humm humm humm til i get to about 60 mph then its fine
if its in your pedals its usually your rear tires if its in your steering wheel its your front tires...
go get them checked out at a local shop. its something you dont wanna put offf till later. i had a similar vibration and it was a chunk of my tire ripped off down to the radials
Oh and as for your title. "that's what she said"
Getaway_Driver
40
09-10-2015 09:11 AM
