went to the dyno.... very upset
Old 05-27-2006, 09:52 PM
Get low
biohazard's Avatar
by looking at that do you guys think i have a pretty good shot at alot more HP?
Old 05-27-2006, 09:55 PM
OniMirage's Avatar
of course dude there is always room for desert err where am I?
Old 05-27-2006, 09:58 PM
mi6_'s Avatar
Originally Posted by campo165
IMO dont waste your money with Z rated...thats a waste for your car...get W rated, probably a lot cheaper and more logical. Z rated is for cars that can go 160+ i believe. You know, you are probably better off doing a 3rd gear pull and maybe letting it shift because if you floor it, it SHOULD run to the rev limiter.
Z-rated tires are any tire with a speed rating of at least 149 MPH. The SS/SC is W-rated, meaning our tires are speed rated up to 169 MPH (so we also carry the Z rating). Tire companies are dropping the use of the "Z" rating because of the confusion this creates.
Old 05-27-2006, 10:00 PM
Get low
biohazard's Avatar
hitting 98.8 Hp at 3,320 RPM in 4th on an auto.... u think i would of hit around 120? since i have mods
Old 05-27-2006, 10:02 PM
Get low
biohazard's Avatar
can i post a vid here or should i just do it in the vid section and link
Old 05-27-2006, 10:11 PM
campo165's Avatar
so you are saying they overlap...word...learn something new everyday, assuming i am understanding your comment correctly. All i know is my dads car is too fast for W rated tires, so he has z
Old 05-27-2006, 10:20 PM
dnbguy86's Avatar
Originally Posted by biohazard
click to make bigger
Holy ****, your making 155ft lbs to the wheels at 3320rpm. That is just amazing, congrats dude, i would be very proud of that. Of course if this graph is that is truly an outstanding number.
Old 05-27-2006, 10:22 PM
Get low
biohazard's Avatar
thnx my self estteem is comming back to me, ill post vids give me like 5 mins
Old 05-27-2006, 10:32 PM
IonNinja's Avatar
I would take your car somewhere else, that is obviously not a legit dyno read.
There is no way in hell you are making 25 less hp to the wheels and 20 more ft lbs of tq at the wheels. The people at that shop did not know how to run your auto on the dyno, I've heard of autos on here before not giving accurate readings.
Old 05-27-2006, 10:41 PM
Get low
biohazard's Avatar
they had a couple ppl doing it and all got the same... the Tq is right... cobalts have the highest Tq rating in their class.... the hp is off because of my fuel cutoff ... look at the RPMs, you hit the Tq peak before Hp thats y its so much higher than the Hp..... anyone wanna back me up... not saying your wrong, i just think wut i saying is right lol
Old 05-27-2006, 10:50 PM
  #36
dnbguy86's Avatar
You kinda got a point, but dont forget about the torque multiplcation that takes place in any auto tranny, that maybe part of the skewed results...
Old 05-27-2006, 10:52 PM
  #37
Get low
biohazard's Avatar
https://www.cobaltss.net/forums/show...253#post313253
videos here
Old 05-27-2006, 11:14 PM
  #38
Clmbngfrk18's Avatar
i cant see the dyno graph could you repst iot i would really like to see it
never mind i can see it now by the looks of the graph i woul deff try somewhere else it shouldnt be dropping off that early
  #39
IonNinja's Avatar
well they had to have run the car in the wrong gear, I've never heard of a car hitting the limiter on a dyno.
that dyno shows like half your powerband so I don't see anyway it could be legit. I still don't think that dyno shows accurate numbers. Your torque may be close to that number but of course your hp #'s are way off.
I still suggest going somewhere else where they can wind it out all the way to 6500rpm.
Old 05-27-2006, 11:17 PM
  #40
Get low
biohazard's Avatar
how could i not hit the limiter on a dyno..... im limited at 105MPh thats nothing, most dont hit a limiter on a dyno cuz they dont have one
Old 05-27-2006, 11:18 PM
  #41
Get low
biohazard's Avatar
there you go... sry its so big but somone needed it posted here cuz they couldnt see it
Old 05-27-2006, 11:30 PM
  #42
"i can see clearly now the rain is gone" lolol
but by the looks of that to me is you need to some how beable to keep it in one gear im assuming they were trying for 3rd but it shifted and that why they both drop off try 2nd its not 1 to 1 but like some one had said if you dyo in 2nd all thetime you be able to see about what you gained and then when hptuners hopefully comes out with a program for the 2.2 you can get a real one done
edit i just looked at chevys site 3rd gear woulld be the best since 3rd is a 1 to 1 ratio but untill theres a something to tune you shifts your kinda stuck with what you got look at is this way you have great trq numbers really low who knows those may keep rising also
Old 05-27-2006, 11:35 PM
  #43
Get low
biohazard's Avatar
creepy the same lyrics came into my head too when i saw it that big... ya i was thinkign 2nd but figured it would be way to far off
Old 05-27-2006, 11:36 PM
  #44
Get low
biohazard's Avatar
o btw they did try to redline 3rd b4 it woudl shift and it went to 4th.... that sheet is in forth gear when i hit the cutoff at 105mph
heres the vids 1 more time.... there back a page cuz of the graph https://www.cobaltss.net/forums/pictures-videos-64/dyno-2-2-but-stupid-fuel-cutoff-fukd-up-21365/
Old 05-28-2006, 12:06 AM
  #45
avro206's Avatar
this does not add up...your hp peak is arund 3000 rpm and falls! It should be rising!
How does the car drive?
Old 05-28-2006, 12:11 AM
  #46
Get low
biohazard's Avatar
god damn this is frustrating me why dont half the ppl get this.... it falls because of a fuel cutoff...... the base model cobalt has a fuel cutoff at 105mph..... that pull was a 4th gear pull and i hit 105 Mph around 3K RPM thats y it drops... the car drives fine
Old 05-28-2006, 12:17 AM
  #47
NJHK's Avatar
Of course you hit your limiter, you were in 4th gear before they decided to get on it.
4th gear is like overdrive...you need to find a way to dyno in 3rd gear. If you can't, don't bother dynoing your car cause it won't be accurate.
Why is everyone talking about tire types? He's on a freakin dyno! He could have steelies on w/stock tires, it doesn't matter.
Old 05-28-2006, 12:25 AM
  #48
Get low
biohazard's Avatar
like i said its an auto, thats how you dyno an auto. i cant lock it into 3rd, only 1 and 2... and btw 4th gear will be pretty damn accurate.... 3rd is 1:1 and 4th is damn close
Old 05-28-2006, 12:32 AM
  #49
charged_sunfire's Avatar
you have only 2 inch piping? my sunfire came with that STOCK, you should have at least that stock, i say bump up to 2.25" and you should gain some hp back, stock you should be around 120ish hp and thats with no mods on the 2.2 eco's.
Old 05-28-2006, 12:36 AM
  #50
Get low
biohazard's Avatar
no it was smaller than 2 stock..... 2 bearly fits up there
Quick Reply: went to the dyno.... very upset
