went to the dyno.... very upset
#52
Originally Posted by biohazard
like i said its an auto, thats how you dyno an auto. i cant lock it into 3rd, only 1 and 2... and btw 4th gear will be pretty damn accurate.... 3rd is 1:1 and 4th is damn close
You need a gear that will allow you to see your whole powerband, not just part of it. Whether you think 4th gear is accurate means nothing because you can't even see your whole powerband. You might be making 155 lbs of torque at those RPMs but say you're making 140 whp at 5500 RPMs, you wouldn't know because you're hitting your limiter.
From my experience and seeing alot of dynos, 98 is way low for a 4-speed 2.2 Automatic, you're looking in the 120 Range stock and should go upwards as you modify.
#53
Trap speed hp calculator
If youhave a quarter mile slip and know the weight of you're car, you can log on to smokemup.com and register and they can calculate you're horsepower from there. I'll try to post a link.
http://www.smokemup.com/auto_math/hp_mph.php
Or try,
http://www.speedworldmotorplex.com/calc.htm
Or try,
#54
Originally Posted by FLM1
Just hang tight. I'm trying to find a math formula so you cam take your car to the track and calculate hp by your time.
Track times have more to do than just how much power you have.
#56
It'll be a hell of a lot more acurate than a dyno run that max's out at 3500 rpm, when your peak hp is close to redline. if you cant hold your trans in a gear that gives you redline you will never get accurate hp numbers.
#57
Originally Posted by NJHK
Those aren't accurate.
Horsepower is the amount of work done in a given amount of time. Example, moving a given amount of weight 1/4 mile in a given amount of time.
#59
There are way too many variables to say "you run XX.X times so you have X amount of horsepower". There have been people with SRT-4s who can't drive worth a damn and miss gears and run high 15s in the 1/4 mile...does that mean they have less horsepower, no. It means they can't drive and messed up their 1/4 mile times but their power still remains the same.
1/4 mile times is a way of seeing how fast you are, not how much power you have.
#60
yah, your dyno place sucks. they only dynoed half the cars hp rating. I have a 2.2 Cobalt Sedan LT and my rev limiter is like 6k rpm or something to that nature. my SS I can wind it up to almost 6500RPM before boing!
When I dynoed my sedan it was 134hp to the wheels stock down to the air filter(btw it's an auto). My SS is getting about 240whp with intake and exhaust.
#61
Get low
how did you dyno the auto? lock it into second or something? or do u have the LS witrh the higher limiter.... the place dosent "suck" they were very good we just couldnt bypass the limiter without a reprogrammer..... we just didint think to try locking it in second... should i try that?
and im not talking about rev limiter thats 4K on the cobalts.... i ment the top speed limiter.... the fuel cutoff
#62
On my shifter, I can put it to "3" and leave it there and it won't go into 4th gear (aka overdrive).
#64
Originally Posted by campo165
Just a thought, I believe torque=horsepower ALWAYS at...5252 rpms? At that moment, the torque should equal the horsepower (according to the formula)
#65
You could try to hold in second gear, and with your foot still in it, shift trans to (D). it should only shift to third gear, and hopefully it'll keep it there close to redline. But I think that if you let your foot out of it at all, the trans will shift into fourth. The dyno guys might not like it to shift that hard though.
#66
1 Post
god damn this is frustrating me why dont half the ppl get this.... it falls because of a fuel cutoff...... the base model cobalt has a fuel cutoff at 105mph..... that pull was a 4th gear pull and i hit 105 Mph around 3K RPM thats y it drops... the car drives fine
#67
Originally Posted by ssnipes
Cause not everyone reads the whole post and some have an SS and dont understand the problem yet.
#69
i've seen alot of dynos and if it didnt downshift to third gear on the dyno they were going to fast when they started. If you were to race at the track it wouldnt go straight into 4th from second it would go to third and hit redline before shifting. they need to be going slow enough for it to down shift to third. the only prob with that is your dyno will only be from like 3 or 4k up to redline you will have nothing before. but it will show you peak hp which is what your after.
#70
#71
First off from reading this there are two big things I noticed.
1. Your Cobalt does not have a 4K rev limiter, it's more like 6500.
2. Bump shift your tranny up from 1-2-3, when you get the go hammer it until it's just before touching the rev limiter. Dyno the 4speed auto in 3, and I guarantee your numbers will be higher.
3. Don't forget to put on the e-brake if you have traction control while on the dyno, that'll mess up your numbers as well.
#72
this is just a question. does the base auto have an overdrive off switch? i know some econo cars do because in fourth they wont make enough power to hual a full load at highway speeds. and off topic, with the aftermarket parts you have, i would recomend going to 2 1/4 pipe. it doeant help your current situation, but it could gain you some numbers
#73
#74
Whats the top speed of 3rd gear?? If thats over 105 do a 2nd gear pull, the numbers will be a little higher than they should but you'll get a good idea of what your car is doing. If third gear doesn't go to 105 then you should be able to do a 3rd gear pull without hitting the limiter, they dyno place should know what to do.
