What clutch and flywheel should I get???
Old 03-07-2009, 10:40 AM
TurboTechRacing's Avatar
The engagment when you first start will be a bit different, but that is the only time. You will get use to it. No different than driving a manual honda and then going to a manual cobalt... Just a little different feel.
Old 03-07-2009, 10:44 AM
MP Cobalt's Avatar
ok cool.
Old 03-07-2009, 12:38 PM
PsychoCam's Avatar
ok so I am more than likely going to stick with my stock flywheel. where do i get a throw out bearing and what kind?
Old 03-07-2009, 12:58 PM
No one makes a "high performance one" all the aftermarket clutch kits work with the "OEM/Stock" one.
GM dealers are the only place to get one...
Old 03-07-2009, 02:31 PM
PsychoCam's Avatar
ok so I will have to get a new bearing at the dealership? correct
Old 03-07-2009, 02:37 PM
That is correct. They are about $70 for the "slave/TOB" which is all one unit...
Old 03-07-2009, 02:58 PM
blu3_v1p3r's Avatar
I got mine from GMpartsdirect. it was like $81 shipped I'll see if i can find a part number for you. The dealer price is like $115.
Part: 12582666*
Category: Clutch Slave Cylinder/Actuator
Description: CYLINDER
Min.Qty: 1
Unit Price: $67.26
Quantity: 1
Ext.Price: $67.26
Core Charge: $0.00
SUB TOTAL: $67.26
SHIPPING: $14.12
TAX: $0.00
TOTAL WITH TAXES: $ 81.38 * indicates special order item, which is a special order non-returnable part.
Old 03-07-2009, 03:58 PM
PsychoCam's Avatar
awesome thank you
Old 03-07-2009, 04:05 PM
06_ion2's Avatar
sweet thanks for that part# was looking all over for that
G85 SS's Avatar
I've got the SPEC Stage 2+ with lightweight aluminum flywheel. Also, if you're going to change the clutch, it's best to change everything. And remember to break it in!! lol
Old 03-07-2009, 04:40 PM
  #36
PsychoCam's Avatar
I am still trying to find out how income is looking but I know I want to put the clutch in b4 I turbo. I have everything to boost just need a clutch so I dont have to worry about that later.
Old 03-07-2009, 04:52 PM
  #37
Jn2
Jn2's Avatar
yeah that sucks, thats why im going to run my sc on 3-4psi until i swap the clutch, than run it at whatever boost the 3" pulley should be putting out once the clutch and flywheel is in
Old 03-07-2009, 11:27 PM
  #38
Sw4y1313's Avatar
Originally Posted by Jn2
i have yet to find this excedy stgII... i dont see it on TTR's site or OTTP, all i see is the excedy stock and excedy STG1
Thats because you have to go elsewhere to find it. I can actually get it since the company I work for is an exedy dealer. I believe I got it for $430 shipped last year.
Old 03-08-2009, 09:21 AM
  #39
06_ion2's Avatar
you will be fine on a stock pulley man ive got 223whp and 246tq on spray with a stock clutch it will hold for a little while atleast
Old 03-10-2009, 01:16 PM
  #40
PsychoCam's Avatar
I think the best place to get it would be ttr. I am going to get the stock flywheel resurficed while i do the clutch install.
what about exedy?
Old 03-10-2009, 05:46 PM
  #41
what about exedy?
Thanks!
Old 03-10-2009, 05:55 PM
  #42
PsychoCam's Avatar
^ NP so will my stock flywheel hold up? to how much hp?
Old 03-10-2009, 06:12 PM
  #43
Jn2
Jn2's Avatar
stock will hold up, how much idk, my buddies sc 2.2 is using a new stock one and its holding up, im going to change the flywheel and the clutch when i do mine, might as well since the tranny will be out to have it down at the same time to save on labor
Old 03-10-2009, 06:19 PM
  #44
PsychoCam's Avatar
very true
05-28-2022 03:47 AM
Zharrington_2010LNF
02-08-2016 01:43 PM
RaginChopsuey
10-27-2015 01:27 PM
SSLOW06
10-01-2015 07:21 PM
jas09ss
09-26-2015 01:06 PM
Quick Reply: What clutch and flywheel should I get???
