What I need to do to turbo.
#51
How hard is it to crack an ECU for a car that all of the other trim levels are cracked? What about the HHR that has a 2.2 in it, do they have anything out for that?
#53
I doubt the HHR has anymore support tuning wise than the cobalt.
#55
I want to run the highest boost I can with out having to build race engine. I'm guessing 10-12 as a conservative number. If 15-20 is acheviable with the same parts as 10-12 then thats what I'll run at.
remember: low boost is your friend on non-purpose built engines. just because they can take the pressure doesn't mean that it'll do you any favors. ideally, you want slight vaccuum at idle to low boost at cruising speeds, with it picking up through the engines natural torque curve.
