What's wrong with my car someone help (long post)
Old 12-23-2012, 11:01 PM
Cobalt08LS's Avatar
im 21 man almost 22
Old 12-23-2012, 11:03 PM
klutch814's Avatar
he cant tune because you dont live near him? bull ****. im in pa and james tuned me. called remote tuning..lol. i hear term's tunes are good. you have lots of options with HPT
Old 12-23-2012, 11:04 PM
Got Brakes?
Sox-Fan's Avatar
your facebook profile says high school, lol.
This. I use term2. He's really really good.
Old 12-23-2012, 11:08 PM
Cobalt08LS's Avatar
profile says class of 2009 and that i work for NYS
thats what he said. said he cant tune me because im not near him..
Old 12-23-2012, 11:10 PM
klutch814's Avatar
idk what to say then man. he remote tunes alot of ppl.
Old 12-23-2012, 11:12 PM
Cobalt08LS's Avatar
i mean i just asked him if noor does the flashing if he'd be able to tune me so ill see what he says
Old 12-23-2012, 11:21 PM
klutch814's Avatar
he may not answer he asked to keep call and txt minimum till after christmas
Old 12-23-2012, 11:38 PM
BankerBalt's Avatar
I tore apart everything from my supercharger kit with an 8,10,12,13,14,15mm sockets and wrenches along with a flathead and Phillips screwdriver in 3 hours... No jack or stands. You should be able to take it off pretty quick
Old 12-23-2012, 11:42 PM
Cobalt08LS's Avatar
just talked to james he said he can tune me
Old 12-24-2012, 12:24 AM
redcobalt07's Avatar
hopefully that solves things for you
Old 12-24-2012, 03:22 AM
  #36
noorj's Avatar
I just texted you brandon, but yeah guys I'll go check the car out. The if you can't connect to the bcm HPT won't be able to connect either so that's the wiring issue that needs to get solved first.
Old 12-24-2012, 06:24 AM
  #37
Cobalt08LS's Avatar
guy who had my car said i needed to get all the accessories that are tapped in to the bcm out of there and relocate them. i have my wideband and radar hardwired there
noor you should talk to the guy who was working on my car and he can tell you the whole rundown on everything because i have a hard time explaining everything.
Old 12-24-2012, 02:47 PM
  #38
sLAsh's Avatar
While I can feel the op's pain I am surprised to hear he found someone willing to tune what is obviously a car with mechanical and/or electrical problems. Most wouldn't wAnt to take a chance of you blowing up your car and blaming the tune.
When you burnt the wires to the trany you may have also melted others wires that are in the same harness causing an intermittent short. You have also hard wired other accessories into the bcm. These could have shorts, open circuits or just simply drawing to much power from a circuit.
If I remember correctly on these cars the circuit for the cigarette lighter is the same one that runs the Obd port. Those are the only things i can think that link you two problems. While two things can fail at the same time I would start with whatever you have added onto that circuit. You may have a short somewhere in there that is going open loop and disconnecting the power from the Obd and/or feeding power back into the bcm. I wouldn't worry about getting retuned until you fix these problems. A short can burn up in multiple spots on a harness and easily compromise the jacket of any wire that runs in the same harness.
Old 12-24-2012, 05:16 PM
  #39
Cobalt08LS's Avatar
the spot where the wires melted on the transmission have been repaired. it was only a small section 2 wires brown and yellowz and the guy soldered in new wires and removed the old ones.
im going to get the wires out of the bcm/fuse box because its my radar and my wideband gauge.
still hope its tune related because i miss my car
Old 12-24-2012, 06:02 PM
  #40
Got Brakes?
Sox-Fan's Avatar
Did noorj go look at it?
Old 12-24-2012, 06:29 PM
  #41
Cobalt08LS's Avatar
no not yet. thurs or fri
Old 12-24-2012, 11:57 PM
  #42
noorj's Avatar
you seem to ask about me a lot, got a crush or something bro
Old 12-25-2012, 12:03 AM
  #43
Got Brakes?
Sox-Fan's Avatar
Certainly not. You seem to be the only one in the area that might be able to figure out what's what with this car. Brandon's a good guy. Nothing more.
Old 12-27-2012, 12:10 PM
  #44
Cobalt08LS's Avatar
car is at the dealer.
they said there was shorts in the engine harness and the bcm was messed up and was throwing codes, one being a code that if it was reset and came back in 60 seconds it needed to be replaced
Old 12-27-2012, 01:42 PM
  #45
chris88z24's Avatar
sounds expensive
Old 12-27-2012, 01:51 PM
  #46
Cobalt08LS's Avatar
sounds expensive
thought id tell you that denooyer dingged up my door with their parts van last month, had to repaint the whole door. lol!
nothing is as bad as your time you had there
Old 12-27-2012, 05:18 PM
  #47
bykryder83's Avatar
Talk to Vince at trifecta....... I like how everyone "thinks" they can tune but most just end up doing more harm
Old 12-27-2012, 05:19 PM
  #48
bykryder83's Avatar
If you lived closer I could prob diagnose and fix it in a matter of hours. Theses are very easy cars to work on and figure out
Old 12-27-2012, 05:49 PM
  #49
Cobalt08LS's Avatar
yeah too many people say that but no ones close
dealer is replacing the bcm and the engine harness and they said that should solve it because the bcm was messed up
Old 01-01-2013, 07:28 PM
  #50
Cobalt08LS's Avatar
so there are 2 things i have questions about that strike my concern. the guy who looked at my car who replaced the tcm told me i have to get all the electrical **** out of the bcm (fuse box) in the fusebox i have my wideband gauge and my radar wires with fusetaps in fuse slots so they turn on and off with the car.
is this safe? or is it not safe?
also i had my custom led tails a member here made for me. they were wired by taping into the tail light harness for them to function. the guy removed all the wiring and has it set back to how the car comes stock because he had a problem with the brake switch circuit (happened bc the bcm was fucked up and not because of the tail lights) i ran my custom tail lights for about a year wayyyy before any of this problem happened.
is having my tails hooked up by tapping into the turn/brake and running and ground wires safe?
because im wondering if i should re hook this stuff up when i get my car back
any input can help
Quick Reply: What's wrong with my car someone help (long post)
