where on earth?!
where on earth?!
can i find the 2.4 IM gasket set at? i have literally looked EVERYWHERE and no luck. i bought the 2.4 IM from crateenginedepot.com but it didnt come with the gaskets so i would like to order them before the IM gets here on thursday. any links suggestions would help thanx, kyle
Depends on year. The newer l61 the 2.2TB bolts right up. If your tb has 5 holes(one is not used at the top left) then its direct fit. If you need to adapter than I'm not sure where to get. I got my as a full kit back then.
would be interested to see what changed year to year though...I know you all have a diff tb, but i didnt think it was a bigger bore...so just more material most likely. I know on the 05-06 they bolt holes line up (you have to swap to the non used hole in the one corner) but it leaves an air gap around the tb that air can leak out of so you have to have an adapter plate that seals it.
my TB did bolt right up and i installed everything corectly but now my idle is at 3100-3600 how can i adjust my idle or is that through a tune only?
my brake booster hose wasnt long enough to reach (BBH 3/4) the IM so what i did was i got a 7/16 hose put it inside the 3/4 along with some strong glue and a screw clamp and with the connection to the IM for it i muscled the 7/16 hose onto that adaptor for it on the throttle body and again held on with a screw clamp. could that be a reason?
