Wheres It At
#51
the b207r comes with a MHI high pressure turbo, the b207l comes with a garret low pressure turbo, but they make massive amounts of trq...that cavy was on 6psi when he made a 13.82@99mph 1/4 mile...youtueb "saab turbo cavalier"...all stock engine, the turbo is not big at all...but its perfect for someone who wants massive trq and good hp
some came with SAI, be sure to get the exhauts manifold from a model that didnt have it
#54
i just saw it like an hour ago. thats crazy. i never knew about that. ****, i learn some new every day. if i felt like gettin another kit id get this, but i think ill stick wit my 25 for now
#56
search for a Saab 9-3 from 2003 and above, i believe the way their search system work u have to select saab 9-3 99+ so select that, than search for exhaust manifold, and than again for turbocharger/supercharger and it will bring results of local junkyards that have the parts available...cheapest way to find them...things u would want to take are
turbo
turbo manifold
oil/water lines
turbo bracket(to help w/the added weight of the turbo)
hot charge piping(helps deal with going under the engine bends for piping)
optionials are:
intake manifold
the rubber piece that connects to the throttle body and the cold charge piping
and a customer downpipe would be required, but should be more than 1500 all said and done...good cheap kit to piece together wish i had gone that route
#59
i have no idea about a stock s2k lol, but once my next set of mods is done i would
and the gains are yet to be seen lol, but from what i hear from alot of people i can expect anywhere from 20-as high as 50 hp gains from what im doing
#60
20 to 50 just on port and polish and what is ur next set of mods..o and that was my other ? ur full boltons,cams,tb and head work and tires, what can u rlly do after that?
#63
he could do block work, bore, stroke, higher compression, etc
#64
So you're spending all this money to beat a stock NA car that has a smaller engine?
#68
No dipshit.
Original s2ks have the 2.0L and are the same speed as the newer 2.2L engines.
http://en.wikipedia.org/wiki/F20C
