why is my 2.2 so slow
#227
but if you do it right your stock engine can handle a 50 dry shot. and im just gonna run that. through all gears computerized on off switch.. my friend hit 14.3 with his set up. in a 2.4
#228
well obviously that is a BIG problem. i was just seeing if it is worth the money compared to something like F/I. not saying that it is any safer, maybe not as likely to put my one and only car out of commision for too long...
#231
if done wrong... yes. just do it right and don't just jump into it. build your car without it, and then if you want more than look into it. if you do decide to go this route the 2.4 manifold will help for sure since it is one solid molded piece instead of 2 glued together like the 2.2 intake manifold
#233
#235
http://www.dynotunenitrous.com/store...?idproduct=100
#236
dude y is ur car so slow..before i had my 2.4 i had a 2.2 that some one drove into me and totalled it..but i ran a 16.2 stock and i was auto...not sure what to tell u
#237
on a 2.2 it will probably be safer than F/I for the simple fact that you will not be using the nitrous ALL the time like you would a sc or turbo. build yourself right and you should be fine. I mean there is ALWAYS risk, but you can minimize that risk.
#238
thank you for making me feel that much worse over the numbers i put up lol and i really dont know what to say excuse wise. it was my first time ever running anything on a 1/4 mile track.... does that help? lol
#239
#241
#243
don't feel bad. and dont worry about the time you run, just try and improve your time... thats the real fun.
#244
yes but then again elevation and temp has alot to do with it. like i said to the one guy who ran the 16.5 on a cool like 55 degree night, boom hes gonna run 16.2s
#246
found something weird out today with my car... i was racing and when it hit 110 the tourqe converter locked in and i couldnt go any faster buty i thought LT's stop ayt 125?
#250
On the stock 16 inch rims with Pirelli's you should top out around 120mph. Since you have swapped rims your speed governor is the same but you speedo may be off.
