Wierd sound on exahust...Suggestion and help needed
So i recently installe dmy full exhaust. This noise has been there since i first put it all on. It seems to be coming from the Downpipe but im not sure. It sound like having a screw with a small washer just shaking on it. I checked all connection and ever is tightened to specs and absolutely nothing is loose. Now i only hear it under acceleration. At WOT i can't hear it. My exhaust ism't loud at all since i got the corsa touring. My only though is that maybe it is a leak in my flex pipe.
Now my question is has anyone else had this problem?
Whats an easy fix?
Thanks for any help posted.
Whats an easy fix?
Have you checked where the header meets the head? Thats where my exhaust was leaking from. After you run it for a while, eventually you should be able to see where its leaking from by the carbon deposits.
you know the heat shield for the rear tranny mount...check to make sure its not toucing the header/dp, cuz i know on mine when i first installed my header and dp, the heatshield was touching the dp, and when the exhaust would vibrate, it would cause it to sound like i had a screw stuck somewhere in the engine bay, but look down there and see, and no dont take the shield off, you need it, just go down there with a pry bar/screwdriver, and bend the shield a bit so they dont touch, and problem solved, lemme know if that was the case
Thanks for the responses.
Oh yeah, get under there when it is cold and gently tap it with a small hammer(use force but not enough to dent it). If it makes a jiggling sound or something like it's loose... Right there's your problem.
DANRICKARD
10-01-2015 12:08 AM
