x8xViperx6x's OFFICIAL 2.2SC build
Old 09-06-2009, 11:50 PM
  #51
x8xViperx6x's Avatar
You guys were right i ended up removing the intake manifold and the bolts fit fine.. Meh.. There are infact m6x1.0 so now going to get the cobra he on. Also bought some hardened brass washers, they seem good.
Does anyone have a picture of a stock heat exchanger on a 2.0 LSJ im trying to mount my LSJ heat exchanger and going to run it inline with the cobra, but I am having technical difficulties mounting it. first off not sure if the hoses go above the radiator or below..? searched around for a few pictures no luck on any good ones...
Old 09-08-2009, 03:35 AM
  #52
pyromaniak04's Avatar
this is vipers buddy helping him and we were wondering if it was normal to hear air coming out of the fuel injectors when manually spinning the supercharger???
and we have the cobra HE up and mounted. pics will be coming soon
Old 09-08-2009, 05:42 AM
  #53
HunterKiller89's Avatar
no...but you cant spin the blower fast enough by hand to create any kind of pressure...
Old 09-08-2009, 07:00 AM
  #54
Ok we yesterday didnt really do anything. Today got everything wired, cobra he mounted and plumbed ready for water. Everything is on just belt and bracket left to go. Tomorrow alt bracket will be here. so will be able to finish and tune! Hopefully all goes well. Any tips for airing out the cobra? Thanks for all the help guys.
Old 09-08-2009, 08:22 PM
  #55
Gene Culley's Avatar
Talking
Good luck. The only thing you can do is just keep adding coolant after you drive it until it isn't going down anymore. There is going to be a lot of air in the system.
If you can hook it up and run it without actually running the car, that is a better idea.
Old 09-08-2009, 08:26 PM
  #56
Jn2
Jn2's Avatar
or you can do this,
-turn pump on
-use hose to act like a long neck
-cut the top off a bottle
-pour in water as it sucks it in
-continue until to air bubbles stop come out
Old 09-09-2009, 01:25 AM
  #57
we were able to to start the HE pump without starting the car and aired out the HE system.
Originally Posted by Jn2
or you can do this,
-turn pump on
i like the coolant bong you fabbed up.
Old 09-09-2009, 01:45 AM
  #58
Jn2
Jn2's Avatar
Lol I actually refer to it as a IV[eye-vee] method lol, I got the idea while watching house :p
Old 09-09-2009, 03:03 AM
  #59
hopefully we wont have to bring out the crash cart tomorrow when we start up vipers car
Old 09-09-2009, 05:34 AM
  #60
meh, technical difficulties, delayed us from starting/tuning.. so tonight everything is done, ready to turn key. Just need to tune bright and early. So will post pics/vid when I get em.
Old 09-09-2009, 12:21 PM
  #61
Jn2
Jn2's Avatar
start the car before u upload the tune to make sure there is nothing wrong, this will help you figure out if its a tune problem or a mechanical/electrical one, your car will idle and drive fine, although it will be running very rich, about 10a/f....so yeah turn it on and check for any leaks, or possible problems....once u determine the car is idling fine, or atleast as fine as its going to idle....upload the tune and go from there...
Old 09-09-2009, 02:53 PM
  #62
or just upload the tune, and then start it, and not worry about flooding the cat. you can check for leaks after the tune's loaded...
Old 09-09-2009, 03:04 PM
  #63
cgrammer's Avatar
U need to hurry up so you can make a vid.
Old 09-09-2009, 03:14 PM
  #64
Jn2
Jn2's Avatar
than he runs into the same issues other member run into, they dont know weather their injectors are wired wrong, or the tune isnt set right...cat will not be harmed from running 10's...trust me, my cat went thru spitting flames from being 9a/f @WOT during a few highway runs...flames were a good foot or so long out the back...when i cut the cat off, looked pretty good...
Old 09-09-2009, 03:17 PM
  #65
ok. makes sense.
Old 09-09-2009, 03:27 PM
  #66
Jn2
Jn2's Avatar
ok. makes sense.
this way he knows everything is wired and set right....and only thing left is to tune
Old 09-09-2009, 04:58 PM
  #67
mmk, well, going to double check everything right now, then i guess start hopefully everything runs..
Old 09-09-2009, 05:06 PM
  #68
Jn2
Jn2's Avatar
post vids...not on yoututbe, photobucket or something so i can see them at work
Old 09-09-2009, 05:10 PM
  #69
She runs, no visible leaks, very rich 10.0 a/f at idle. Sounds great vid be up in a few!
Vid here: http://s19.photobucket.com/albums/b1...t=MOV06482.flv
Old 09-09-2009, 05:13 PM
  #70
Jn2
Jn2's Avatar
nice sound about right, vids
Old 09-09-2009, 05:14 PM
  #71
theres you go vid is up!
Old 09-09-2009, 05:19 PM
  #72
Jn2
Jn2's Avatar
nice watching it now
video doesnt show anything.... ??? just someone walkingo utta the car
Old 09-09-2009, 05:28 PM
  #73
***** you uploaded the wrong vid
not you jn2
  #74
I posted the wrong one, dur, then my computer decided to restart, so uploading the right one now, one min.
Old 09-09-2009, 05:34 PM
  #75
Jn2
Jn2's Avatar
lol ok
Quick Reply: x8xViperx6x's OFFICIAL 2.2SC build
