x8xViperx6x's OFFICIAL 2.2SC build
#101
its on the intake manifold where the iat2 would normally go, the iat1 sensor doesnt fit so it required sometime of gasket, (I used a small piece of rubber hose cut a hole in it) and also needs something to hold it in, due to it not having the same hole as the iat2 to hold it in place. I used a piece of metal with a hole in it to keep it down. Works.
#102
would appreciate it, just got back from data logging low boost, 0-5psi, seems to have gone well. Did see between 11-10 afr was bouncy since i didnt hold boost to long. But will go from there, did find another problem... meh.. oil is leaking from the dipstick where it meets the pan.. how do I go about fixing that? I think I read somewhere ionninja just took his out I believe.. ill have to research, gotta leave for work in an hour though.. cant drive with an oil leak..
ok, nice, so, were on the same page lol.. the body of the supercharger is touchable, but the snout was boiling hot.. was just making sure.. its getting hotter out iat is now 114* ambient is 100*
#103
#104
iat is on my interceptor my coolant temp shown on the dic was between 199-226* only stayed at 226 for a bit then lowered to 208. I was driving fifty and under with no boost. Its about twenty miles. It was only high at full stops at like red light traffic. Whats everyone elses temps look like?
#107
Speak for yourself, lol j/k. There are some of us 2.2's who can see IAT2's.
#108
haha you mean you just you :P
thats cool how you made it happen though.
#110
What do you normally see after wot? Or sitting at a red? I am running like a very little coolant and mostly water. When i put the radiator hose oni just drained the coolant (most of it) and replaced with water..i figured az doesnt if cold so no worries for freezing.. I may go back to coolant if it keeps it cooler.. It may have air still left in the system maybe..
#114
#116
Ok i feel a lot better.. So whats to hot.. ? It gets fn got here too, very much a downside.. Although at night its not so bad high was like 189-199. Still awaiting vince and an update.. she seems to be running great though.
#119
if he is using water.. Coolant has a higher boiling temp. but thats still real hot. Im thinking about switching back to coolant.. Just cause i dont want it to evaporate..
#120
The cooling systems on these cars are really great from the factory. Even some of th race cars GM made, still retain an unmodifed cooling system.
Yes coolant helps with boiling but its mostely the system being pressurized that raises the boiling point in the water. If the car is ever gettin above 225 steadily then there is a prob with the system. A leak, faulty thermostat, fans or the cap not holding pressure.
I'm gonna be doing a flush on my cooling and plan on runnng more water then coolant. Gonna do more like a 80/20 water/coolant mix since water cools better then coolant. We rarley see freezing here plus I have a garage to keep the car in, so not worried about it freezing over.
#122
Just like ssfam said soon as you turn the ac on the fan will kick in i did this just to cool my car at a red. Worked great came down fast. At night i have no probs its 185 at cruise. Oh and still awaiting an update for my tune... Eh.. Gene or anyone else that tuned from trifecta take this long? Im just anxious.
#125
Ok great day. Updated tune. Went wot! Only saw 13.5-14psi but in 2nd gear i had the interceptor recording hp it said 291 thats kinda high? Sounds to good to be true is there something i need to change like altitude? Just curious.. Also ambient is off doesnt seen normal.. Going to data log here in a few when it cools abit more.
