x8xViperx6x's OFFICIAL 2.2SC build
#152
So how are my fellow supercharged 2.2s running?
Its getting purty cool out, its 4:30am when i get out of work and its getting chilly 56*-60*
The cool weather has affected the HP got some more interceptor recordings, took a pic of top of 2nd and 3rd.
2nd
3rd
Cant wait to go to the track for times, and dyno for actual numbers, hopefully soon..
2nd
3rd
#154
Work Fridays/Saturdays, so when I get one off.. I maybe able to trade a day with my partner, so make a date, well go!
Ok, well I said before I had some problems here is how I fixed them!
First off, I could not find the m8x1.25x130mm alternator bolts ANYWHERE, not even online or copper state bolts. So this is what I did..
Got a threaded rod about 3ft in length (for extra just in case..) then used my dremel and cut three individual rods about 150mm (left alittle extra to use pliers to tighten to block.
I lined up the bracket and alternator and put the three rods in and hand tightened them, then I put some flanged nuts on all three rods, about half way then used some vise grips to tighten the rods (not super tight) then tightened down the nuts worked great!
Next I needed to make a bracket for my cobra heat exchanger, so went to Home Depot, and found these:
They were like $5 each, but they were together, so the lady rang them up together...
I then cut them (well my friend did..) just the cross braces off. and shortened the rest to make them like this..
Its also spray painted black, and the parts where the heat exchanger touches the brackets has felt on there.. went to walmart in the pluming section, bought some exhaust hanger (autozone or checkers have it too...) and bent it around the HE, thats it, $8-10 later. Oh and mounted with self tapping screws.
here is after.
Hope this helps the next person..
Oh, and some vids here: http://www.youtube.com/user/x8xViperx6x
here is after.
#156
Just reading through this topic, as I have mounted an SC on my European 2,2.
Did you guys check the LSJ dipstick length correctly? I noticed on my conversion that the important bit, that what sticks out into the oilpan, is a bit different length than on the 2,2. This due to the LSJ's different oilpan/dipstick mounting level...
#157
Very nice, you gotta get it to the dyno, we need some real numbers. I checked online, maybe not boltdepot, couldnt find them.. plus it was like the day of that I actually noticed that I didnt have them, they were the only bolts I had to find. I went to copper state and like every local hardware store around no luck, closes was a 100mm and a 110mm.. wasnt sure they would fit, so I fabbed some up. Works great. it was like less than 3$ for the rod and nuts. Plus had extra.. just in case..
#158
Right now Vince is tuning my MAF curve for my CAI. Once I have that taken care of I will be taking it to the dyno.
On boltdepot, I had the same issue because I was trying to buy grade 12 bolts. They only make the 130 lengths in grade 8.8.
http://www.boltdepot.com/product.asp...&cm=20&cd=1252
#159
when all you supercharged guys get a free minute can you visit this thread and give me your opinion please!
https://www.cobaltss.net/forums/show...96#post4394996
