Zam's first mod- K&N intake
Old 01-14-2011, 01:50 AM
  #101
csa1982's Avatar
Originally Posted by pursuitforever
which one is the sai? the dark black one or the light black one?
In the 5th pic, its the tube that comes up in the middle and rests on the valve cover.
Old 01-14-2011, 09:22 AM
  #102
jmesl8er's Avatar
16's are fine
16's will be fine if you lower it, I'll put a pick of mine on here thats lowered with the stock 15's on it, still looks ok
Old 01-14-2011, 02:34 PM
  #103
jmesl8er's Avatar
Winter Wheels with B&G Lowering springs
http://
http://
http://
Factory 15's for the winter on B&G Lowering Springs
Old 01-14-2011, 03:12 PM
  #104
emilypaige's Avatar
I like. Yeah I'll probably stick with 16's. No need for big wheels, especially since I plan on bringing my car to the track a lot....weight reduction =P lol
Old 01-14-2011, 03:15 PM
  #105
Maupin SS/SC's Avatar
get some 16 or 17 rpf1 if you want lightweight what bolt pattern are you? 4x100?
Old 01-14-2011, 03:18 PM
  #106
pursuitforever's Avatar
Originally Posted by jmesl8er
http://
Do u find a problem driving in the winter with ur car lowered? i live in canada and i didnt get springs cause of the snow
Old 01-14-2011, 03:34 PM
  #107
Leafydialupking's Avatar
I have no problem in my car in the snow lower. I drove though the 8" that blew back onto the roads yesterday without too much issue.
Old 01-14-2011, 03:38 PM
  #108
emilypaige's Avatar
Yes sir, 4x100
Old 01-14-2011, 05:00 PM
  #109
Enkei 4x100 16 rpf1 image by ghg78 on Photobucket done
Old 01-14-2011, 05:56 PM
  #110
jmesl8er's Avatar
Front bumber makes a good snow plow
Old 01-14-2011, 06:21 PM
  #111
Black08SSTC's Avatar
if you wanna go when ur back in school up by me ill go with you when the weather gets warmer. I use to go every weekend, and wednesdays and fridays lol
Old 01-14-2011, 07:14 PM
  #112
emilypaige's Avatar
I def will! Where do you usually go?
Old 01-14-2011, 09:15 PM
  #113
06_cobalt's Avatar
Originally Posted by DaFlyinSkwirl
enough to watch her posts and laugh at all the dudes like you
Do you really get on here just to watch her posts?
Anyways Emily I have been wondering where does the SAI tube go on the intake? Cause I didn't see it in any of the pics. Been curious since I have SAI as well.
Old 01-15-2011, 12:44 AM
  #114
emilypaige's Avatar
The SAI connects to the end of the intake near the filter on the bottom where you cant see it. The K&N kit comes with an extension that replaces the plastic on the SAI.
The kit also comes with a plug in case you dont have SAI.
Old 01-15-2011, 01:34 AM
  #115
Normally i go to Island Dragway but i have gone to Englishtown on occasion.
Old 01-15-2011, 01:36 PM
  #116
06_cobalt's Avatar
Awesome thanks for the info.
Old 01-15-2011, 02:03 PM
  #117
Nothin Stock
gotboost?17's Avatar
congrats on the new intake :-)
Old 01-17-2011, 07:14 PM
  #118
DaFlyinSkwirl's Avatar
nothing else of value goes on here so... yea
best track in NJ is Atco raceway. Cheapest price and a lot less busy than E-town.
unless atco has raised their prices... e-town charges $30 for 3 runs only.
atco was less than $20 and you get unlimited runs.. if its a slow day, you can easily go home with 10 time slips or more.
Old 01-17-2011, 07:21 PM
  #119
06_cobalt's Avatar
Not to thread jack but Skwirl what all is done to your cavi?
Old 01-17-2011, 07:41 PM
  #120
engine:
-LSJ bottom end (stock except removed balance shafts)
-L61 head
-ARP headstuds
-L61 headgasket (for now)
-LSJ External Oil cooler adapter
induction:
-custom intake manifold w/ LS1 throttle body
-3" charge piping has yet to be fabricated
-T4 "full 60-1" turbo .82a/r on the hotside
-sidewinder-style custom turbo header
-external tial 44mm gate (may have to go with 38mm for the time being)
-tial 60mm BOV
-still deciding on air/air or air/water intercooler
fuel:
-12 gallon RCi fuel cell
-Aeromotive A1000 external fuel pump
-All fuel lines replace with -AN lines (-8AN feed, -6AN return)
-750cc low impedance injectors
-Aeromotive compact EFI afpr
-modified fuel rail for NPT/-AN fittings
brakes:
-removed ABS
-removed brake booster
-Wilwood tandem master cylinder
-modified brake pedal for higher ratio (full manual now)
-all brake lines replumbed
-10psi residual pressure valve for rear drums
-proportioning valve for rear brakes
-metering valve for front brakes
chassis:
-removed power steering/ looped rack
-removed HVAC
-removed BCM
-removed PCM
-removed SRS
-removed Radio
-complete re-wire from bumper to bumper
-solid steel fabricated upper engine mount
-solid steel fabricated lower dog bone engine mount
-solid steel fabricated transmission mount inserts
-corbeau A4 fixed back racing seats
computers:
-specter eMS stand alone EFI computer (megasquirt 1 based)
-MSD 6212 ignition box controlling ignition
-MSD twin tower coils (eliminated ICM)
-Aeromotive FPSC (prolonged fuel pump life)
-aluminum mounting plate fabricated in place of HVAC unit
-Racepak IQ3 LCD digital dash (soon to come)
suspension:
-STD R3 coilovers with added thrust bearings to front springs
-Seam-welded A-arms
-Prothane poly a-arm bushings
-Addco front sway bar
I haven't set the ride height yet in the picture in my sig. The car is sitting right now for winter but I'm hoping to be race ready by spring time. Going to be running a 10" slick in the front, and I'm shooting for 400whp with the stock LSJ in a car that weighs less than 2400lbs
Old 01-17-2011, 07:52 PM
  #121
06_cobalt's Avatar
Holy **** I was expecting a small view of your car not the whole thing . That's alot of stuff.
Old 01-17-2011, 08:31 PM
  #122
Wow thats some good stuff right there. Ive always wanted to hit up Atco but the ride is just waaaay to long. Island dragway is like that on some nights, i remember getting 20 something runs in one Wednesday night. it was pretty sick for $15. Maybe one weekend when they open we could all meet up there or something, go both days.
Old 01-17-2011, 08:40 PM
  #123
ecot3c inside's Avatar
naawwwws and tune! haha
DarrenGC
12-24-2021 01:55 PM
01-12-2016 12:01 AM
no_ss
10-18-2015 11:58 PM
09-26-2015 06:44 PM
OrangeCoba
09-25-2015 06:06 PM
Quick Reply: Zam's first mod- K&N intake
