Zex Wet Kit Install!!
Old 07-16-2007, 02:56 PM
  #51
2fastforyouraSS's Avatar
looks good my jank is hidden too.. dynotune bottle warmer is a must!!
Old 08-22-2007, 11:39 PM
  #52
lil_kano's Avatar
Originally Posted by WheatRocket
You need to remount your bottle or it won't be no where near what it should be. It needs to go straight, with the top facing the front of the car because there is a tube that goes inside the bottle all the way to the bottom and when you floor it the N2O sinks the the bottom so you're getting straight nitrous instead of a sketchy mix. Nitrous while still inside the bottle is in a liquid form so when you floor it the nitrous flows back, as you have it mounted now you will only get 100% when the bottle is completely full.
i know about the tube and i did turn my bottle so that it was in the right position once the cart was in motion. i even conacted zex about it with pictures and they said my setup was fine. i actually had it mounted "the right way" and it doesn't feel any different to me. i also have the dynotune bottle heater and purge kit now and it all runs fine.
hey 2fast looks bad ass by the way^^!!! where' you tap for your heater. i did mine by my ebrake but i wasn't sure about doing it by the battery
05-28-2022 03:47 AM
bigdeertz
11-17-2016 09:41 AM
justinchinn
10-02-2015 12:18 PM
09-28-2015 12:51 PM
metroplex
09-27-2015 07:48 AM
Quick Reply: Zex Wet Kit Install!!
