zzp 2.4 swap to 2.2
zzp 2.4 swap to 2.2
who has done the 2.4 intake manifold to the 2.2 from zzp? I am having some issues the adapter sent to me does not work and i was wondering if anyone else had these issues????
well i bought the kit that includes the 2.4 manifold and the 2.0 tb and spacer and then the wiring harness connector. Since the 2.2 has a 6 pin connector and the 2.0 has a 8 pin connector the adaptor harness sent i would think would plug into the tb and then connect and reduce to the 2.2 wire harness and make it all work. But the adaptor sent to me is 8 pin on female and male side so i dont know
o really? see i mean i bought the whole kit from them.kinda upset it not working but i emailed them and im sure they will do that they can to help
Just run the 2.2 or 2.4 tb. You shouldnt have any issue running the 2.2 tb. Im not a 2.2 guy though. But I believe maven is still running a 2.2 tb on his 2.4 manifold.
You will lose Alot low end with the lsj tb unless your forced inducted.stick with 2.2 tb until you do nitrous/forced induction.if you really want to use that tb then there is a Wiring diagram I used to wire my lsj tb to my ls which is 6 pin to 8 on the lsj I'd link you but I'm on my iPod
You'd need a tune if you plan on running any tb other than the 2.2l youre car will not run with the 2.4l tb or any other. Some have used the JET MAF sensor and ran the 2.4l tb, but a tune is always your best bet
so you could run them but more than likly need a tune at that point?
I have to 2.4mani and I am running my stock 2.2 throttle body. I am porting and polishing a 2.4tb but you have to be tuned in order for it to work properly. did you bore out the map sensor hole? I no that was a bi*ch, but thats the only problems ran into
besides that the adapter wire that was sent to me is incorrect so havent completely finished this waiting to hear back from zzp to see if wrong adapter was sent
