ZZP Turbo Kit anyone?????
hey was lookin to turbo my L61 and i was wondering if any1 out there has the zzp turbo on they're 2.2 or they're 2.4...eve if sum1 can contribute some feedback of what theyve heard or experienced w/ this kit...thnx
looks to be a good kit, i would recommend the intercooled version...lemme find their list here to help you out some more...
Stage 2 adds 8 psi and 100-110 WHP, mid to low 13's capable.
Includes:
*Bullseye s256 turbo
*Powdercoated charge piping
*Liquid/air Intercooler
*Heat exchanger
*IC pump and lines
*All stainless and aluminum tubing
*Includes 304 stainless 2.5" downpipe
*ZZP 304 stainless turbo manifold
*All feed and drain oiling lines
*silicon boots
*Stainless clamps
*Custom tuned PCM <<<<YOU DO NOT NEED THIS!!!!
*TiAL 38mm wastegate kit
*Blow off valve
*All installations accessories
*39# injectors
*Intake tubing and filter
*Spark plugs <<<< have them send NGK ltr6ix-11(1 step colder)
*2 bar map <<<< YOU DONT NEED THIS
all that coupled with a trifecta tune and you wll be set
Includes:
*Heat exchanger
*IC pump and lines
*silicon boots
*Stainless clamps
*Blow off valve
*39# injectors
Includes:
*Heat exchanger
*IC pump and lines
*silicon boots
*Stainless clamps
*Blow off valve
*39# injectors
Includes:
*Heat exchanger
*IC pump and lines
*silicon boots
*Stainless clamps
*Blow off valve
*39# injectors
ill probably b takin u up on that ..where u located?
Last edited by jerseyfatboy; 11-02-2009 at 02:24 AM. Reason: Automerged Doublepost
oo ok cool...o nd my internals shuld b good rite? i figure maybe jus upgraded spings nd retainers nd maybe a low stage clutch should do the trick
cool sounds lie a plan...as soon as the install is done u'll b the 1st to kno bro
Last edited by jerseyfatboy; 11-03-2009 at 12:29 AM. Reason: Automerged Doublepost
ok cool hows ur clutch nd tranny holdin up n e way?
Last edited by jerseyfatboy; 11-05-2009 at 08:24 PM. Reason: Automerged Doublepost
huh? ur asking if i wana dyno tune it?
ok im assuming 8psi shuldnt overwhelm the stock clutch too too much..
Last edited by jerseyfatboy; 11-06-2009 at 12:11 AM. Reason: Automerged Doublepost
plan to install myself in a friend's garage .. well wat will it cost me for a non-dyno tune?
Last edited by jerseyfatboy; 11-06-2009 at 12:21 AM. Reason: Automerged Doublepost
if you would like we can either do a dyno or street tune.. however for a dyno tune you will have to pay for dyno time .. if you have a long stretch of road you can get some good 2-3, and some of 4 if not all, pulls in then a street tune can be extremely accurate and in some cases better then a dyno tune as they're real world conditions.
I do tuning through trifecta performance.. he has a great track record with tuning these cars
