ZZP Turbo....Stage 2...2.2...
#232
between turbo and tb. the gauge is fine. in P and N the car doesn't wanna make boost but on the road i hit 1psi.............................................. .................................................. .................................................. .................................................. .................................................. .................................................. ...............yeah you read that right. i'm scared to death of boost. i wanna get my idle dialed in before i even consider going ***** to the wall.
#233
between turbo and tb. the gauge is fine. in P and N the car doesn't wanna make boost but on the road i hot 1psi.............................................. .................................................. .................................................. .................................................. .................................................. .................................................. ...............yeah you read that right. i'm scared to death of boost. i wanna get my idle dialed in before i even consider going ***** to the wall.
#239
#247
#248
just had to upload a tune to get the car to ingore the maf during idle. these cars seem to have a mind of their own at times and the dp is yours whenever your ready. even found the plug for the wideband bung if your not running one yet.
#250
i'm never into easy. got up to 5psi tonight and i must say holy ******* **** does this turbo pull. still working the tune out. and the sc kit will have it's own headaches not to mention their stage 1 sc kit cost more then stage 1 turbo and will make less boost as compared to the s256 supplied with the turbo kit. to each his own.
