ZZP Turbo....Stage 2...2.2...
#426
Well as soon as it hits 21psi I have to shift to 3rd because it goes through 2nd so damn fast.
#427
#428
#432
#433
#434
spanky are you still running the stock clutch? how well does it hold up so far? cause i dont think ill have enough money for the turbo AND the clutch.. so i want it to be able to last a bit longer lol. Im sure i should be ok as long as i dont beast on it
#437
His is an auto. Stock trans though, I am fairly certain.
#438
auto, and straight stock for the moment but as with all things that will change with time. soooooooooooooooooooooooooooo got the good word from the wife and we'll be back in the shop in a week or so.
any guess' what the power's gonna be looking like @ 15psi? was gonna run off the stock w/g spring but i'm thinking i might as well throw a boost controller on there and have a ball.
#439
any guess' what the power's gonna be looking like @ 15psi? was gonna run of the stock w/g spring but i'm thinking i might as well throw a boost controller on there and have a ball.
#441
#444
#446
F23 is stout it just has weak synchros. This is coming from experience, if you can think of a way of destroying a tranny I've done it(daily driving the **** out of it, taking it to the strip and ******* it for 20 passes on slicks, you get the idea). They both have their flaws.
#447
#448
Stage 3 is just stage 2 with the extended tip turbo and bigger injectors I believe. And on the clutch issue, I drove from south Florida to North Dakota on the stock clutch and haven't had one problem yet... I won't be putting my stage 3 clutch in until I need to.
#449
noo, im getting stage 2 turbo kit. i was talking about stage 3 clutch lol. for when mine goes out. probably better than getting stage 2 then replacing it with stage 3 later. waste of money..
#450
ohh okay. The stage 3 is cheaper for some reason anyways haha. The stock clutch should be fine until you save up money for a stage 3. How many miles do you have on your stocker?
